 Post subject: Second monitor choice greyed out
PostPosted: Sun Mar 15, 2020 4:06 am
Hi,
I am new to Nexus and wanted to try it.
I would like to put it on my second screen but the option is greyed out whereas it is said in the description this option is available even for the free version.
Any idea why?
I've searched the forum but could not find a similar topic.
K.
 Post subject: Re: Second monitor choice greyed out
PostPosted: Sun Mar 15, 2020 4:10 am
Oups, finally found a similar post about dpi differences after a last search.
Sorry.
PostPosted: Sun Mar 15, 2020 9:29 am
No problem. Eventually I will have to add per-monitor DPI support, but it's definitely not an easy thing to do the way Microsoft has implemented that beast.
PostPosted: Sat Sep 19, 2020 2:05 pm
Curious if we can expect an update anytime soon to be able to put docks on monitors with different DPI settings.
I recently purchased Nexus for use at both home and work. It's a great tool and a great replacement for Fences. Unfortunately at home and work, I have 3 monitor setups all with different DPI settings. It would be more than ideal to be able to move the dock off of my main monitor onto a secondary, and amazing to be able to run a dock on each monitor.
I can see from the comments on various posts here that this does not look to be the easiest of tasks, but it would be good to know if it's coming somewhere down the road or not likely to happen anytime soon.
Thnx
Users browsing this forum: GPT [Bot] and 87 guests
