 Post subject: File browsing with large icons
PostPosted: Wed Aug 19, 2020 11:07 pm
Hello! :wink:
I have and use too many files and programs.
So I was thinking of agrouping them by folders on the dock.
Currently with my Nexus Dock.. when I put a folder with many files inside the dock it is displayed with very small icons and a text on the right side.
I would like to know if it is possible to change the display mode of these icons when you click on the dock folder so that it appears as I show in the example of the image (big icons), large icons and small text, or with no text if possible just icons (as if they were normal desktop size icons)
I can't find the option to do that and the small icons with text on the right make my head hurt when reading, they are very small, sry ):
How to change them? Any solution to make it bigger
Thank you very much,
Paulo
PD: Example image: https://static.makeuseof.com/wp-content ... enshot.png
 Post subject: Re: File browsing with large icons
PostPosted: Thu Aug 20, 2020 12:18 am
You can do that with Grid Stacks, but you will need to upgrade either to Nexus Ultimate or Winstep Xtreme.
The free version of the Nexus dock does not support Grid Stacks.
Users browsing this forum: Majestic-12 [Bot] and 70 guests
