 Post subject: Nexus Dock on 2 Monitors
PostPosted: Tue Aug 18, 2020 5:54 am
Hello,
I've two monitors and I what see the same dock on both of them.
What should I do for this?
Thanks and greetings
Itsme
 Post subject: Re: Nexus Dock on 2 Monitors
PostPosted: Tue Aug 18, 2020 1:07 pm
ItsMe wrote:
Hello,
Itsme
You could start by searching this forum. ISTR that this question has been asked more than once before.
PostPosted: Tue Aug 18, 2020 1:36 pm
Hi,
I give up on page 5 :(
They have all an other problem...
I can see only one dock on one monitor, I want the same dock on both...
PostPosted: Tue Aug 18, 2020 8:40 pm
Hi!
The free version of Nexus, if that is what you are using, only supports one dock.
On the paid versions (Nexus Ultimate and Winstep Xtreme) you can have as many docks as you want, but there is no 'automatic clone' function (e.g.; changes made to one dock automatically reflect on another).
You can, however, set up one dock in one monitor as you want it and then make a duplicate of it (settings and contents) via the 'Duplicate Dock' feature. You can then place the second dock on your secondary monitor, but any changes later made to one dock will have to be manually duplicated into the other dock.
PostPosted: Thu Aug 27, 2020 7:54 am
ah, ok...
Thanks a lot :)
Users browsing this forum: Google [Bot] and 62 guests
