 Post subject: Is there a way to get the Windows Start button on the dock?
PostPosted: Fri Aug 07, 2020 1:16 am
Hi everyone,
I am new to Nexus and I was wondering if there was a way to add a Windows Start button? I couldn't find the correct path to open up the start menu just like if you pressed the windows key on the keyboard or just clicked the button from the microsoft taskbar.
 Post subject: Re: Is there a way to get the Windows Start button on the do
PostPosted: Fri Aug 07, 2020 6:10 am
Yes, by using one of the over 80 built-in Internal Commands. Click HERE for a list and description.
PostPosted: Fri Aug 07, 2020 4:12 pm
Thank you so much, you dont know how many hours i spent searching for that!
Users browsing this forum: Bing [Bot], Google [Bot] and 84 guests
