 Post subject: Help with autohide feature
PostPosted: Wed Aug 05, 2020 1:52 pm
Hello friendos, its my first topic here, so idk if this is the right place to create it, so i'm sorry in advance. I'd like to my dock to autohide when theres a maximized window on focus (like chrome for example), if i move the cursor to the edge the dock comes up and dont steal focus (nice, thats what i want), but it wont autohide again after i take cursor away from it, i'd like to know if there's a way to autohide again. I got the autohide for maximized applications option checked and hide automatically after a quick pause unchecked. Thanks!
 Post subject: Re: Help with autohide feature
PostPosted: Wed Aug 05, 2020 5:54 pm
Hex_cz wrote:
I'd like to my dock to autohide when theres a maximized window on focus ... hide automatically after a quick pause unchecked.
Why do you have that option unchecked?
PostPosted: Wed Aug 05, 2020 7:11 pm
Thanks for the response! Well, that option conflicts with a particular behavior i want that is dock to be visible when i press win+d. Basically the behavior i want is: autohide (with slide animation) when a fullscreen app is on focus, when i touch the edge while on a fullscreen app, the dock should slide up without stealing the focus from the fullscreen app (i usually do that to check what time is it and other stuff), when i remove the cursor from the dock it should autohide again sliding down. When not on a fullscreen app, the dock should be visible all the time, including on desktop view (win+d). Tried a couple things with checking / unchecking both options, but i couldnt accomplish all the behaviors i wanted unfortunately. I'd like to know if its possible to achieve these behaviors, thanks a lot and sorry for being so inconvenient wanting all that xD
Users browsing this forum: Bing [Bot], Google [Bot] and 80 guests
