 Post subject: nexus sub dock arrows
PostPosted: Thu Jan 31, 2019 5:18 pm
I tried searching for this but couldn't find it. I wanted to know how to customize the arrows in the subdocks? Are they customizable??
 Post subject: Re: nexus sub dock arrows
PostPosted: Thu Jan 31, 2019 5:31 pm
Hi Dawn!
Yes, they are. You may only provide nxSubC.png if you want, the dock will do the rest:
NeXuS Sub-dock Indicators
nxSubC.ico/.png/.tif Sub-dock closed indicator for a dock attached to the bottom screen edge.
nxSubCtop.ico/.png/.tif Sub-dock closed indicator for a dock attached to the top screen edge.
nxSubCleft.ico/.png/.tif Sub-dock closed indicator for a dock attached to the left screen edge.
nxSubCright.ico/.png/.tif Sub-dock closed indicator for a dock attached to the right screen edge.
nxSubO.ico/.png/.tif Sub-dock open indicator for a dock attached to the bottom screen edge.
nxSubOtop.ico/.png/.tif Sub-dock open indicator for a dock attached to the top screen edge.
nxSubOleft.ico/.png/.tif Sub-dock open indicator for a dock attached to the left screen edge.
nxSubOright.ico/.png/.tif Sub-dock open indicator for a dock attached to the right screen edge.
nxSubM.ico/.png/.tif Sub-dock mouseover indicator for a dock attached to the bottom screen edge.
nxSubMtop.ico/.png/.tif Sub-dock mouseover indicator for a dock attached to the top screen edge.
nxSubMleft.ico/.png/.tif Sub-dock mouseover indicator for a dock attached to the left screen edge.
nxSubMright.ico/.png/.tif Sub-dock mouseover indicator for a dock attached to the right screen edge.
PostPosted: Thu Jan 31, 2019 5:42 pm
Many thanks Jorge, this was just what I needed.
PostPosted: Thu Jan 31, 2019 5:47 pm
My pleasure. You have a PM, by the way, just in case you didn't notice. :)
PostPosted: Wed Jul 08, 2020 4:57 pm
Hay guys, with the sub-dock arrows, what is the default file path for the images used?
Can't seem to find the files anywhere, all I want to do is just make them completely transparent (I don't like the arrows).
Thanks in advance for the reply
PostPosted: Wed Jul 08, 2020 4:59 pm
They are on the same folder as the bitmaps and configuration paths of the current theme being used for that dock.
PostPosted: Wed Jul 08, 2020 5:15 pm
Thanks for the quick reply,
Not to sound too dumb, but what is the exact file path for that? If I select my theme then open its folder, they are not there.
Edit: Nvm! I just created new files following your earlier post, worked perfectly, thanks for your time!
PostPosted: Wed Jul 08, 2020 5:22 pm
Glad you figured it out! :)
PostPosted: Fri Jan 27, 2023 8:34 am
So, uh, what is the folder path then. Still not able to make these arrows disappear. Dock theme is "K-TEK4D3" btw.
PostPosted: Fri Jan 27, 2023 8:55 am
In the Themes tab of Preferences there is an 'Open Folder' button. That should open the folder to the currently selected/applied theme in Explorer.
Users browsing this forum: Apple [Bot], GPT [Bot] and 50 guests
