 Post subject: Dock not starting
PostPosted: Sat Jun 27, 2020 4:29 pm
This issue happens occasionally. When I logon to my PC, the shelf starts but, the dock does not start. Has anyone had this issue before and how can I fix it permanently? For now, I'm closing shelf and then restarting WinXtreme app which then starts both shelf and dock
I'm using version 19.4 on Windows 10 64bit.
Thanks.
 Post subject: Re: Dock not starting
PostPosted: Wed Jul 08, 2020 4:47 pm
Hmmm... next time it happens open WorkShelf Preferences, go to the Docks & Shelves tab, select the culprit dock and then click the Locate button. What happens?
Is it possible the dock is hidden or actually behind the taskbar, for instance?
Users browsing this forum: Apple [Bot], Google [Bot], GPT [Bot] and 73 guests
