 Post subject: How do I get all the menu items?
PostPosted: Sun Jun 14, 2020 6:47 am
I have a hotspot that is set to "Display a Menu Showing the Contents of a Folder" and it points to the folder:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Multimedia\
It doesn't display all the items that show up if I click "All Programs" | "Multimedia".
 Post subject: Re: How do I get all the menu items?
PostPosted: Sun Jun 14, 2020 6:48 am
Here's a screenshot of both menus.
PostPosted: Mon Jun 15, 2020 2:11 am
Is it possible some of the missing items are from another "user", like the C:\Users\Public or something like that?
I think All Programs tries to incorporate the current user and the public user stuff. But I'm not sure.
PostPosted: Tue Jun 16, 2020 6:24 am
I'm sure it's something like that. But how do I get my hotspot to show me the same thing the NS Start Menu shows me?
PostPosted: Wed Jul 08, 2020 5:19 pm
It does.
PostPosted: Sat Jul 11, 2020 7:16 pm
It does.
Nice to have you back. So how do i get my hotspot to show me the same thing?
PostPosted: Sat Jul 11, 2020 7:33 pm
It does.
Err, shouldn't you set the path for your hotspot to ...\All Programs\Multimedia to get the same menu?
PostPosted: Sun Jul 12, 2020 8:02 am
Right click on the hotspot, select Properties. In the Hotspot Properties dialog, select Edit Hotspot. Go to the second page of the Hotspot Wizard dialog that pops up and you can specify a second folder. The contents of both folders will appear automatically merged in the menu.
PostPosted: Tue Jul 14, 2020 7:25 am
Okay, I will try that. Currently, the hotspot points to "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Multimedia\"
Users browsing this forum: Amazon [Bot], Apple [Bot] and 98 guests
