 Post subject: Issues with 2 monitors
PostPosted: Wed May 20, 2020 9:35 am
I have 2 monitor connect Via 2 DP on my VGA
Im using Nexus Ultimate, and 2 docks, 1 dock to primary horizontal monitor, 1 dock to vertical monitor, But when i on or off 2nd monitor, all my dock lost their blank space dock. Look like this,
When i want to 2 dock back to normal status, (like image below), i must to restart (exit and start) nexus dock. How can i fix my problem when i on or off 2nd monitor.
(HAVE A BLANK SPACE BETWEEN DOCK AND SOFTWARE)
 Post subject: Re: Issues with 2 monitors
PostPosted: Mon May 25, 2020 2:35 pm
That looks like a video driver issue (or one of the monitors has a different color depth than the other). Sorry, not sure what else I can tell you.
PostPosted: Sun May 31, 2020 9:06 am
Yes, my first monitor is UP2516D (10bits) and my second is P2419H (6 bits)
And how to fix it, my vga driver is AMD (RX580)
Users browsing this forum: Majestic-12 [Bot] and 23 guests
