 Post subject: Website shortcuts created by Google Chrome?
PostPosted: Sat May 23, 2020 4:28 am
i have several website shortcuts on my desktop that i created using google chrome (settings > more tools > create shortcut > open as window) - i would like to add these to my nexus dock but can't figure it out, i keep getting errors, is this not possible?
 Post subject: Re: Website shortcuts created by Google Chrome?
PostPosted: Sat May 23, 2020 5:30 pm
anyone?
PostPosted: Sun May 24, 2020 6:30 pm
The part that starts with --profile-directory (in other words, everything after the double-quote character after chrome-proxy.exe portion) needs to be cut from the Filename field and pasted into the Arguments field of the Dock Entry Properties dialog box.
Make sure there isn't even a space character after that double-quote character.
Filename: "C:\Program Files (x86)\Google\Chrome\Application\chrome_proxy.exe"
Arguments: --profile-directory=Default --app-id=adnlfjpnmidfimlkaohpidplnoimahfh
(Assuming I typed those correctly, that's what you need to copy and paste to the two fields.)
PostPosted: Mon May 25, 2020 2:18 pm
What Ric said. :)
Users browsing this forum: Apple [Bot], nexter and 22 guests
