 Post subject: Tasklist Actions aren't working - 19.2
PostPosted: Thu May 21, 2020 5:23 pm
Hey folks,
Just downloaded and configured your free version of the dock - it's awesome.
One problem tho, it doesn't close the app on middle mouse button.
I've tried to test other options(for the left and right click) to check if this is working and the answer is no.
Everything else seems to be awesome, except this.
Any workarounds / solutions? This is super freaking me out each time.
 Post subject: Re: Tasklist Actions aren't working - 19.2
PostPosted: Fri May 22, 2020 3:50 am
yovowi6219 wrote:
Hey folks,
Do you have your middle mouse button mapped to do something else? For instance, I have used Logitech mice forever, and always mapped the middle button to be a double-click. If you have it mapped to be something other that a middle button, it won't work as a middle click.
PostPosted: Fri May 22, 2020 10:08 am
I have Logitech M330 with no additional software for the mouse, that being said, I do have 7+ taskbar tweaker installed, but I tested the nexus dock without 7+ and it's still the same.
Also, as I mentioned earlier, settings that should affect the left and right mouse buttons are also doesn't work.
I'm using Windows 10 1909.
PostPosted: Mon May 25, 2020 2:29 pm
Can you please post a screenshot of
Nexus Preferences -> Tasks -> Advanced dialog, so I can see what you have your Tasklist actions configured to?
A screenshot of the Content tab in Preferences would help too.
PostPosted: Sun May 31, 2020 11:47 am
Sure thing, here you go:
PostPosted: Wed Jun 03, 2020 1:58 am
The dock must be set to show running applications otherwise it just acts as a launcher, and in your case it isn't.
In the Content tab of Preferences, enable the 'Show running applications in this dock' setting.
Users browsing this forum: Majestic-12 [Bot] and 20 guests
