 Post subject: Running indicator problem
PostPosted: Wed May 13, 2020 10:55 pm
Hi,
I've been using Nexus Dock for long time but last time error with Indivator occured. At this moment there absolutely no indicator for any running application. I haven't changed any settings. When indicator has disappered I tried to turn it off and on in setting but it didn't work. What can I do do fix it?
 Post subject: Re: Running indicator problem
PostPosted: Wed May 13, 2020 11:19 pm
Is the 'Show indicator on shortcuts to applications that are currently running' setting enabled?
Have you rebooted your system already?
In the Appearance tab of Nexus Preferences (or the dock Properties dialog) do you have a bitmap selected as the indicator?
Users browsing this forum: Majestic-12 [Bot] and 23 guests
