Board index : Winstep Forums : Translations  [ 8 posts ]
 Post subject: or is configured main menu Russian
PostPosted: Tue Aug 17, 2010 12:30 pm
 Post subject: Re: or is configured main menu Russian
PostPosted: Tue Aug 17, 2010 3:20 pm
What? Sorry, don't know what you mean?
PostPosted: Tue Aug 17, 2010 4:10 pm
I'd guess how to get Winstep into Russian... But the question should be clearer. Anyone else here who can speak Russian and English? :P
PostPosted: Tue Aug 17, 2010 4:21 pm
If he runs Winstep Xtreme v10.6, Russian is already available. Older versions do not have multi-language support.
PostPosted: Sun May 10, 2020 11:17 am
Can anyone give me the latest English.ini file?
PostPosted: Mon May 11, 2020 6:56 pm
It's in the application itself...
C:\Users\Public\Documents\WinStep\Languages\
You should use the included Winstep Translator Helper though.
PostPosted: Tue May 12, 2020 12:36 pm
Yep. I know that. Sorry for not explaining anything.
First of all I'd like to say thank you for that programm. It's awesome! The functionality is great! Of course there are much to be done.
I just wanted a dock, like in mac, but xtreme version is much more better! So I decided to use it. But when I've switchet to Russian, I found out that some text is still in English. "That's no good" - I thought. I can speak English without any problem. But what if not all Russian-speaking users can do that? (Frankly speaking I don't know if Nexus is popular in Russia ) So minor corrections should be done.
For example the text in hotspot activation settings "If you apply a hotspot to the Desktop, the left click delay helps distinguish... and so on"
I have found it in English.ini file,and was a little bit puzzled. This text was translated, but NextSTART didn't want to show the translation. So I started to compare the text in the file, and the one in hotspot settings. And as I thought, they turned out to be different.
The one in the file says "If you apply a hotspot to the Desktop, NextSTART is unable to distinguish if you are single clicking on the hotspot or double clicking on an icon below it. Increasing the left click delay makes NextSTART wait a little longer before activating the hotspot to help it distinguish between single and double clicks. Keep in mind that the higher the delay, the longer it will take for all your left click hotspots to activate, therefore it is highly recommended that you set the delay to None when you have no hotspots attached to the Desktop." But it's different in the NextSTART.
When was it created? How many changes to the programm have been done since then? What menus have been added? I don't know, so that's why I've asked about THE LATEST VERSION ENGLISH.INI file.
PostPosted: Tue May 19, 2020 4:27 pm
So am I still waiting
For someone to start helping
Can find a good reason
Can find hope to belive in
Post new topic Reply to topic Board index : Winstep Forums : Translations  [ 8 posts ]
Users browsing this forum: No registered users and 18 guests
