Board index : Winstep Forums : Off Topic  [ 5 posts ]
 Post subject: I have problems logging
PostPosted: Wed Aug 08, 2007 6:58 am
Hello! Help solve the problem.
Very often try to enter the forum, but says that the password is not correct.
Regrettably use of remembering. Give like to be?
Thank you!
PostPosted: Wed Aug 08, 2007 7:08 pm
Sorry, no idea what the problem might be. You seem to have logged in just fine this time.
PostPosted: Thu Aug 09, 2007 3:02 am
Most likely, you are either manually clearing your cookies or some program or another is automatically clearing your cookies for you. Without the cookie, the forum doesn't remember you. As for remembering your passwords, you could always look into a program for remembering your passwords. My favorite is RoboForm, because it installs itself as a toolbar within the browser, it automatically prompts you every time you enter a new password if you want it to save it, and it can fill out many web forms other than just passwords. I've also used Key Wallet, and liked it, but it ran as a separate program kind of like AIM, only for passwords, rather than instant messaging. You'd click what site you wanted to log onto and it'd open the appropriate page and log you on. Those pieces of software can be found here:
RoboForm: http://www.roboform.com/
Key Wallet: http://www.keywallet.com/
The main reason I can think of to choose Key Wallet over RoboForm is that Key Wallet is free, whereas RoboForm is not. But RoboForm is a more powerful tool, and I think it's worth the money.
PostPosted: Thu Aug 23, 2007 2:10 pm
It was a bot. We just wasted our time. :cry:
PostPosted: Fri Aug 24, 2007 4:13 am
Well, at least now, if somebody really DOES have a problem, they can read this response. But they'll probably just ask instead of searching, anyway. :wink:
Post new topic Reply to topic Board index : Winstep Forums : Off Topic  [ 5 posts ]
Users browsing this forum: No registered users and 10 guests
