 Post subject: Weather Module Bug - Day "name" does not match weather data
PostPosted: Tue Feb 04, 2020 10:19 pm
Firstly, WinStep Nexus rocks!!!
I am using Nexus 19.2 and have noticed a bug in the 5 day weather forcast pop up.
The 5 day weather forcast pop up "day" label is out by one day and does not match
the forcast data strings returned from the log
i.e.,
MSN Website displays SAT 8 with High is 25, Low is 24
Nexus 5 day popup "day" label for this info is SUN 9, not SAT 8
Interestingly today is Wednesday, and the results from your query return Tuesday to Saturday, not Wednesday to Sunday
I am thinking something is missing or maybe wrong in your query string
OS -> Windows 10 v1909
TimeZone -> (UTC +10:00) Brisbane
Nexus Weather Module Settings
- Country -> Australia
- State -> QLD
- City -> Mount Cotton
- METAR Code -> (blank)
- Weather.com Code -> (Blank)
Advanced settings -> Defaults
Get Weather log is as follows
<snip>
* METAR Connection Failed...
No Valid Codes
No Valid Codes
/data.aspx?src=vista&weadegreetype=c&culture=en-US&weasearchstr=Mount%20Cotton%2C%20QLD%2CAustralia
weather.service.msn.com
HTTP/1.0 200 OK
Server: Microsoft-IIS/10.0
X-ActivityId: 0cea9c5e-6c86-4ce0-bde0-8cd84112e956
X-AspNet-Version: 4.0.30319
X-Powered-By: ASP.NET
Cache-Control: public, max-age=555
Date: Tue, 04 Feb 2020 21:24:37 GMT
Content-Length: 1530
Connection: close
<weatherdata xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><weather weatherlocationcode="wc:ASXX0011" weatherlocationname="Mount Cotton, Australia" url="http://a.msn.com/54/en-US/ct-27.638,153.247?ctsrc=vista" imagerelativeurl="http://blob.weather.microsoft.com/static/weather4/en-us/" degreetype="C" provider="Foreca" attribution="http://www.foreca.com/" attribution2="Foreca" lat="-27.638" long="153.247" timezone="10" alert="" entityid="8441789" encodedlocationname="Mount+Cotton%2C+Australia"><current temperature="22" skycode="9" skytext="Light Rain" date="2020-02-05" observationtime="07:00:00" observationpoint="Mount Cotton, Australia" feelslike="22" humidity="86" winddisplay="22 km/h Southeast" day="Wednesday" shortday="Wed" windspeed="22 km/h" />
<forecast low="23" high="27" skycodeday="9" skytextday="Light Rain" date="2020-02-04" day="Tuesday" shortday="Tue" precip="" />
<forecast low="21" high="25" skycodeday="9" skytextday="Light Rain" date="2020-02-05" day="Wednesday" shortday="Wed" precip="100" />
<forecast low="23" high="25" skycodeday="4" skytextday="T-Storms" date="2020-02-06" day="Thursday" shortday="Thu" precip="100" />
<forecast low="24" high="26" skycodeday="4" skytextday="T-Storms" date="2020-02-07" day="Friday" shortday="Fri" precip="100" />
<forecast low="24" high="25" skycodeday="4" skytextday="T-Storms" date="2020-02-08" day="Saturday" shortday="Sat" precip="100" />
<toolbar timewindow="60" minversion="1.0.1965.0" /></weather></weatherdata>
Got MSN Data!
<end snip>
Screen Shots of Nexus 5 day for foracst and MSN Web page is attached in PDF
https://1drv.ms/b/s!AgSfMo7RGUsahrMcN7T3E91BiKKfKQ?e=uyax1J
Other than this annoying bug, your app is flawless
 Post subject: Re: Weather Module Bug - Day "name" does not match weather d
PostPosted: Wed Feb 05, 2020 3:52 am
Thanks for bringing this to my attention.
As you may or may not know, the primary weather forecast feed used by Winstep applications was, until recently, Weather.com, with other weather feed providers being used only as backups (i.e.; for redundancy) if the primary failed for some reason (initially the other feeds came from Google, MSN and Yahoo).
Google terminated their feed years ago, Yahoo put theirs behind AUTH authentication a few months ago and now Weather.com has also terminated their feed.
Thankfully Winstep applications still had the MSN feed to fall back on.
The problem is that because it was so seldom used - if ever - the code to parse the MSN feed was never tested under all conditions.
The issue is actually not in the code by itself, but rather in the MSN feed. The code assumes, as it did with the Weather.com feed, that the first forecast line is for the current day (as having a forecast line for the previous day doesn't even make sense) but apparently it is the latter that is actually happening.
For instance, here is currently 3:43 AM of the 5th of February. Polling the MSN feed returns current conditions as having been observed at 3:00AM 2020-02-05 (which is fine) but then the date of the first forecast line reports the forecast for 2020-02-04, which was yesterday. This doesn't even make sense, but is what it is.
I am now waiting to see when the first forecast line starts correctly refering to the 5th of February (i.e.; giving us a forecast for the rest of the current day) to see how best to handle this 'quirk' in the MSN feed.
PostPosted: Wed Feb 05, 2020 4:53 am
What about using some of the freebie feeds out there as used by Linux 'docklets/desklets' etc.? Or are they only free for free s/w? That MSN feed seems pretty rubbish anyway - even further out than Weather.com for accuracy here, and lacking things like pressure and visibility.
Anyway, just a thought.
How will it all end?!
IN FIRE!
PostPosted: Wed Feb 05, 2020 5:52 am
Thxs Jorge for the feedback and response
Lol, yes wt? about MSN feed returning yesterday???
Agree best approach would be to process the "forcast" elements as such to ignore stale data
Process Forcast Elements {
if Forcast.date lt now ("2020-02-04" < "2020-02-05")
next element
fi
Appreciate your support
PostPosted: Wed Feb 05, 2020 8:17 am
Yep, changed the code so that in that situation the last forecast day ends up showing N/A (since we really have no data for that day).
PostPosted: Wed Feb 05, 2020 1:01 pm
Well, it's now 1 PM of 05 Feb and the first forecast entry of the MSN feed is STILL showing the forecast for the 4th of Feb. Beginning to wonder if their 5 day forecast is actually a 4 day forecast in practice.
PostPosted: Thu Feb 06, 2020 8:16 am
Hi Jorge
Did some research over past 24hrs and found multiple references to MSN Weather Service as the "4" day forecast. I am thinking others have come to the same frustations.
Looking back at the bug from another perspective, the real issue is that the shortday name doesn't match the hi/lo data... and would therefore assume that the shortday name is not pulled from the XML data. If the shortday name was pulled from the same element as the hi/lo data, then the popup forecast would be correct. Ok it would start with yesterday, then today, followed by the next 3 days BUT it would be correct. I recommend
that this approach be taken
Tim
PostPosted: Thu Feb 06, 2020 8:29 am
Problem is that a forecast referring to a day in the past is neither useful NOR a forecast - it would just be confusing. So, unfortunately what is going to happen is that either the last day is always going to show up as N/A whenever using the MSN feed OR only 4 days/icons are shown, instead of the usual 5.
PostPosted: Thu Feb 06, 2020 9:23 am
And that works as well
PostPosted: Wed Apr 15, 2020 5:42 pm
I have the same problem as timbo63 on feb. 6 2020.
One day difference between you and Microsoft. Microsoft say today and you say tomorror. Sorry can not paste image to show you. is there something that can be done to fix it or not.
PostPosted: Wed Apr 15, 2020 6:08 pm
Open Preferences, go to the Advanced tab, enable 'Notify me of beta (test) versions', click the 'Check for Updates' button and let it install the v20.3 beta.
PostPosted: Wed Apr 22, 2020 3:58 am
Ok, nearly there
I downloaded Beta version and checked. Didn't work in the morning but did in the afternoon???, so just to make sure I tested this on another PC.
At 0819hrs I get 5 days, but at 1351hrs I correctly get 4 days as expected.
My current TimeZone is +10hrs (Brisbane)
See attached examples
File comment: 5 Day Forcast
File comment: 4 Day Forcast
PostPosted: Wed Apr 22, 2020 4:23 am
Hmmm... looks like a timezone problem. Being on GMT here doesn't help.
Do me a favor: tomorrow at 8AM, when it shows the 5 day forecast, open the Weather module settings and click the Check Weather button. This will create a Weather.log log file in
Rename that file to Weather8AM.log
Now, at 1PM, when it's showing the 4 day forecast again, do the same thing, open the Weather Module settings, click the Check Weather button, rename the log file to Weather1PM.log
Then please send both log files to the Winstep support email address. :)
PostPosted: Wed Apr 22, 2020 4:30 am
Will Do
PostPosted: Thu Apr 23, 2020 12:12 am
Please find attached requested files
At 9:06am, 5 days displayed with incorrect information
<Log>
No Valid Codes
No Valid Codes
HTTP/1.0 200 OK
X-ActivityId: 93142644-f87c-4af6-98fd-353fe1138c55
Akamai-Age-Ms: 1587596403216
Cache-Control: public, max-age=217
Date: Wed, 22 Apr 2020 23:06:26 GMT
Content-Length: 1534
Connection: close
<weatherdata xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><weather weatherlocationcode="wc:ASXX0011" weatherlocationname="Mount Cotton, Australia" url="http://a.msn.com/54/en-US/ct-27.638,153.247?ctsrc=vista" imagerelativeurl="http://blob.weather.microsoft.com/static/weather4/en-us/" degreetype="C" provider="Foreca" attribution="http://www.foreca.com/" attribution2="Foreca" lat="-27.638" long="153.247" timezone="10" alert="" entityid="8441789" encodedlocationname="Mount+Cotton%2C+Australia"><current temperature="23" skycode="9" skytext="Light Rain" date="2020-04-23" observationtime="08:40:00" observationpoint="Mount Cotton, Australia" feelslike="23" humidity="66" winddisplay="11 km/h South" day="Thursday" shortday="Thu" windspeed="11 km/h" /><forecast low="18" high="28" skycodeday="31" skytextday="Clear" date="2020-04-22" day="Wednesday" shortday="Wed" precip="" /><forecast low="17" high="25" skycodeday="30" skytextday="Partly Sunny" date="2020-04-23" day="Thursday" shortday="Thu" precip="20" /><forecast low="18" high="26" skycodeday="34" skytextday="Mostly Sunny" date="2020-04-24" day="Friday" shortday="Fri" precip="20" /><forecast low="19" high="25" skycodeday="30" skytextday="Partly Sunny" date="2020-04-25" day="Saturday" shortday="Sat" precip="30" /><forecast low="17" high="26" skycodeday="34" skytextday="Mostly Sunny" date="2020-04-26" day="Sunday" shortday="Sun" precip="60" /><toolbar timewindow="60" minversion="1.0.1965.0" /></weather></weatherdata>
Got MSN Data!
<End Log>
At 10:06am, 4 days displayed with correct information, 5 day is N/A
<Log>
No Valid Codes
No Valid Codes
HTTP/1.0 200 OK
X-ActivityId: d0c90a51-5b79-49f0-af4d-c8b76e1714ef
Cache-Control: public, max-age=289
Date: Thu, 23 Apr 2020 00:05:24 GMT
Content-Length: 1538
Connection: close
<weatherdata xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><weather weatherlocationcode="wc:ASXX0011" weatherlocationname="Mount Cotton, Australia" url="http://a.msn.com/54/en-US/ct-27.638,153.247?ctsrc=vista" imagerelativeurl="http://blob.weather.microsoft.com/static/weather4/en-us/" degreetype="C" provider="Foreca" attribution="http://www.foreca.com/" attribution2="Foreca" lat="-27.638" long="153.247" timezone="10" alert="" entityid="8441789" encodedlocationname="Mount+Cotton%2C+Australia"><current temperature="25" skycode="9" skytext="Light Rain" date="2020-04-23" observationtime="09:30:00" observationpoint="Mount Cotton, Australia" feelslike="25" humidity="60" winddisplay="13 km/h Southeast" day="Thursday" shortday="Thu" windspeed="13 km/h" /><forecast low="18" high="28" skycodeday="31" skytextday="Clear" date="2020-04-22" day="Wednesday" shortday="Wed" precip="" /><forecast low="17" high="25" skycodeday="30" skytextday="Partly Sunny" date="2020-04-23" day="Thursday" shortday="Thu" precip="20" /><forecast low="18" high="26" skycodeday="34" skytextday="Mostly Sunny" date="2020-04-24" day="Friday" shortday="Fri" precip="20" /><forecast low="19" high="25" skycodeday="30" skytextday="Partly Sunny" date="2020-04-25" day="Saturday" shortday="Sat" precip="30" /><forecast low="17" high="26" skycodeday="34" skytextday="Mostly Sunny" date="2020-04-26" day="Sunday" shortday="Sun" precip="60" /><toolbar timewindow="60" minversion="1.0.1965.0" /></weather></weatherdata>
Got MSN Data!
<End Log>
Users browsing this forum: nexter and 24 guests
