Board index : Winstep Forums : General Discussion  [ 147 posts ] Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
 Post subject: Re: So, what's next after v19.2?
PostPosted: Sun Mar 15, 2020 9:31 am
I think. However, I think it should not stop manually checking for updates, ideally.
Hmmm... perhaps you are right? Other Ric, what do you think?
PostPosted: Sun Mar 15, 2020 11:53 pm
I agree. When I read n-Ric's reply last night, I thought, "There should be a way to undo that." So, maybe if the user does a manual check, also remind the user they've turned off auto-checking and then give them the option to turn auto-checking back on or leave it off.
PostPosted: Mon Mar 16, 2020 11:03 am
Ok, I changed the Update Manager so that it will also report hidden updates if the user performs a manual check for updates.
PostPosted: Mon Mar 16, 2020 4:36 pm
Great, Jorge. :)
And, I also agree with DD_Ric and his further suggestion.
PostPosted: Fri Mar 20, 2020 1:46 am
Forgot. Dragging docks works like a charm here. :)
PostPosted: Tue Mar 31, 2020 10:34 am
after the update my shelf is broken, once it collapses its not responding to clicks on any of the tabs or mini tabs untill i exit the app an restart. drawer and docks work
still present in the current beta
PostPosted: Tue Mar 31, 2020 12:19 pm
Thanks. Don't go anywhere, I might have some questions later. :)
I was wondering where and how you were. Everything ok?
PostPosted: Tue Mar 31, 2020 3:43 pm
everything ok, didnt get new topic notifications in my mail and with everything going on with work and mexican beer i forgot to visit
PostPosted: Sun Apr 05, 2020 5:57 pm
still waiting for the questions :)
PostPosted: Mon Apr 06, 2020 3:43 am
I know, sorry... Why do you think I haven't made an official release yet? :)
I need to apply your settings here, but all of this Corona beer business has been messing with me. :P
PostPosted: Mon Apr 06, 2020 4:30 am
new bug, maybe
https://prnt.sc/rtsnnf
as soon as i lock my screen and unlock it, my desktop background gets covered in grey with dots
why do i think its winstep connected?
a)it started shortly after if not imediately after new beta
b)https://prnt.sc/rtsp0i its not full screen , it starts a bit below the workshelf
c) it goes away after i restart workshelf
PostPosted: Mon Apr 06, 2020 6:20 am
Exactly how are you locking your screen?
PostPosted: Mon Apr 06, 2020 7:07 am
win+l
it seems to only happen if desktop background is set to slideshow
aaand it stopped happening, ill update if i further pinpoint
PostPosted: Sat Apr 11, 2020 9:57 pm
Figured out what was happening and fixed. Now I have to make sure the fix didn't break other stuff.
PostPosted: Sat Apr 11, 2020 11:07 pm
thats always fun :)
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 147 posts ] Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
Users browsing this forum: Amazon [Bot], GPT [Bot] and 200 guests
