 Post subject: Weird shaking while activating by screen edge bump
PostPosted: Tue Mar 10, 2020 2:20 am
Hi guys, I'm totally new to this software but started to love it very soon :)
However, sometimes there is a weird shake when the dock was activated by a bump, wondering if anyone knows the solution:
When I press Win+D, my dock did not show up either.
My settings are here:
Many thanks!
 Post subject: Re: Weird shaking while activating by screen edge bump
PostPosted: Tue Mar 10, 2020 2:26 am
To disable the 'shake' effect when activating the dock: Preferences -> Behavior tab -> Auto-Hide Settings button -> Select 'Disable final boing effect'
As for the dock not being visible when pressing WIN+D, is it actually visible BEFORE you press WIN+D~?
PostPosted: Tue Mar 10, 2020 2:45 am
Thanks!! Really quick response.
Umm I don't actually know if I understand the feature wrong, but I would like to keep my dock activated on my desktop and hide it when any other window has the focus.
PostPosted: Tue Mar 10, 2020 3:42 am
Keep auto-hide enabled then. You might also want to enable the 'Hide or collapse automatically only when other windows have the focus' setting in Preferences -> Behavior tab -> Auto-Hide Settings.
WIN+D (Show Desktop) has nothing to do with this though, it does not automatically activate the dock. If you want to know that the dock is operating properly, show it then press WIN+D while the dock is still visible - if the dock is operating normally and the 'Keep this dock visible when pressing WIN+D (Show Desktop)' setting is enabled, it will remain visible.
Users browsing this forum: Apple [Bot], Google [Bot] and 35 guests
