 Post subject: need old version of winstep
PostPosted: Sun Dec 01, 2019 5:23 pm
Hidoes anyone know where to find winstep old versions download?
I have reinstalled the software but uts 19 version and i need 18version.I have send two emails to tech support but didn't hear back from them and it has been a week since them. Want this done before my trial expires by jan 21.
Thx for help
 Post subject: Re: need old version of winstep
PostPosted: Sun Dec 01, 2019 5:52 pm
You can download Winstep Xtreme v18.12 from HERE.
This said, it's probably better if you backup your settings to an external drive or a folder *outside* the Winstep folder structure and then uninstall v19.2 before installing v18.12 (and/or you uninstall but tell the uninstaller to keep your settings).
This because setup will not overwrite newer files.
PostPosted: Sun Dec 01, 2019 6:33 pm
Thank you
Users browsing this forum: GPT [Bot] and 39 guests
