 Post subject: Issue with Nexus Dock on Dual Monitor
PostPosted: Mon Oct 14, 2019 6:58 pm
Hi all,
I have a dual monitor setup with separate docks locked to each monitor.
Anyone know why I keep getting my secondary dock move to the same place as on my primary monitor? Both docks are locked to the bottom of each screen so I cant understand whats going on.
Its quite frustrating as I have to unlock the dock which is stuck behind the other, move it back to the 2nd monitor and re-lock in place, which would be fine, but that in itself is a clunky process.
I'm guessing this has something to do with turning the 2nd monitor off. But does anyone know of a fix for this?
Thanks.
 Post subject: Re: Issue with Nexus Dock on Dual Monitor
PostPosted: Tue Oct 15, 2019 3:14 am
Well, yes, of course, otherwise the dock would remain inaccessible and off-screen. Docks and other Winstep objects automatically reposition themselves into the visible screen area whenever monitors are turned off or you lower the screen resolution. This ensures you can always access them.
The real question is: why do you turn off your secondary monitor? For instance, I have a triple monitor system here and all three are always turned on (even if in power saving mode).
Anyway, from v18.12 forward, Winstep implemented automatic multi monitor profiles. This means what you are experiencing should not happen when you turn off the second monitor (unless you are running a previous version or you turned that feature off in Preferences), i.e.; docks can have different positions for different monitor configurations.
What version are you running (and is it Nexus Ultimate or Winstep Xtreme) ?
PostPosted: Tue Oct 15, 2019 10:21 am
Ah thanks, forgot about the monitor select in preferences. That will make things easier even if the dock does revert back to the main monitor, but hopefully that fixes it.
Latest version of Nexus Ultimate
PostPosted: Tue Oct 15, 2019 10:56 pm
If you go to
C:\Users\Public\Documents\WinStep\
is there a Profiles sub-folder? If so, how many files are in it?
Here is what is supposed to happen: when you run your system with a single monitor on, that creates a monitor profile. That profile has the positions of the docks and other Winstep objects for that particular screen resolution and screen position (for instance, docks A and B are on monitor 1, A at the top, B at the bottom, or B can be disabled in this case).
When you then add a second monitor (or turn it on) this creates a separate profile, so docks (etc) can have a different position for that particular configuration (e.g.; dock A is on monitor 1 and dock B is enabled and on monitor 2).
These profiles are created automatically when you change the screen resolution, the number of monitors, or their relative positions.
For instance, when you turn on monitor 2, a profile for monitor 1 (the previous configuration) should be automatically created and the position and status of all dock(s) etc for that configuration saved.
You then re-arrange your docks and when you switch monitor 2 off again (thus reverting to your previous configuration) a new profile is created for the two monitor configuration and the position and status (enabled/disabled) of the docks is automatically changed to what was previously saved in the single monitor profile.
Every time you switch between one configuration and the other the position and status of the docks, etc, are also saved in their respective previous configuration profiles and those in the new configuration profiles are applied.
This is how it should work at least, provided you have NOT disabled this mechanism by selecting the 'Disable multi-monitor profiles' setting in the General tab of Preferences. Please make sure that setting is NOT selected.
So, I am not sure what is happening there. When (and why, out of curiosity) do you turn your second monitor off? Is your system in a power saving state when you do that?
PostPosted: Wed Apr 29, 2020 5:22 pm
Sorry to reopen this thread. I'm quite new i cannot find a solution.
I have 2 docks, one for each nmonitor. My sistem is a laptop + external monitor.
When I disconnect the external monitor, both docks overlap.
Disable multi-monitor profiles is not selected but still overlap.
Any other solution?
Enrique
PostPosted: Wed Apr 29, 2020 5:29 pm
Not sure what you expect, the application is behaving as designed: if an object is outside the visible range, it is automatically moved to a visible monitor. This makes sure you can always access that object, even when you reduce screen resolution or when you turn off a monitor.
Here is what you can try, though: while running with a single monitor, disable the secondary dock in the Docks & Shelves tab of Preferences. Now plug in the external monitor, go to the Docks & Shelves tab of Preferences and re-enable the dock. Move it to the secondary monitor if necessary.
Now unplug your external monitor and, all going well, the automatic multi monitor profiles will kick in and keep the second dock disabled when you are running a single monitor, and enable it automatically when you plug in your external monitor.
PostPosted: Thu Apr 30, 2020 7:53 am
Thanks, it worked!
PostPosted: Thu Apr 30, 2020 8:23 am
Thanks for letting me know. :)
PostPosted: Sun Aug 11, 2024 6:52 pm
I have three monitors but the settings of workshell do not show this third monitor.
PostPosted: Sun Aug 11, 2024 7:59 pm
Download THIS FILE from the Winstep web site, unzip and run TestMonitors.exe then post a screenshot of the results, please. This will show what the Winstep application sees in terms of monitors and screen resolutions.
PostPosted: Sun Aug 11, 2024 8:59 pm
Oke here it is.
PostPosted: Sun Aug 11, 2024 9:56 pm
Winstep thinks that the 1280,720 monitor is my primary but the 3840 is. And i have two 1920 screens.
PostPosted: Mon Aug 12, 2024 3:06 am
What you see there is what Windows is telling the Winstep application regarding the number of monitors and their resolution. Since you claim to have two 1920 monitors, this means Windows is lying.
This happens because one or more monitors have mismatched screen DPIs. Winstep applications are high DPI compatible, but they are not PER-MONITOR high DPI compatible. This means that for everything to work properly all monitors must have the same DPI (e.g. all 100%, or all 125%) otherwise Windows will lie to the application about the real screen resolutions and what you get is the result.
PostPosted: Mon Aug 12, 2024 6:39 am
Thanks that is the solution, i can now place the dock on all screens.
Mondriaan :D
Users browsing this forum: Apple [Bot], Bing [Bot], GPT [Bot] and 21 guests
