 Post subject: So whats new in 19.4B and beyond
PostPosted: Sat Aug 24, 2019 10:16 am
Hi Nice to have you back Jorge...
I/we understand that a new Beta is in operation 19.4 Excellent.
Is this just a minor maintenance build that is due, fixing minor features?
Or should we be testing some wiz bang feature? Don’t make us have to crawl through everything looking………
I must omit that I have been lacking in regard to Winstep Application’s, its loaded but I don’t seem to be using it as much as before. I have been tinkering with SD->RightClick It’s no longer fit for purpose it seems to be losing its settings. Do you have plans of any sort to produce something that works/alters the Desktop context menu? It is an excellent way of launching applications.
To be effective in testing the latest incarnation of winstep Xtreem it would be helpful to know what to look at?
If the object in question is : NextStart then I am afraid that is not running and I personally don’t use it.
Can you reveal what the next feature is that you are planning?
What’s in it plz?
oOSGearOo Aka Steve....
Technobable
 Post subject: Re: So whats new in 19.4B and beyond
PostPosted: Sat Aug 24, 2019 5:50 pm
You can use NextSTART's ability to create your own menus + hotspot activation to emulate RightClick's behavior.
PostPosted: Sat Aug 24, 2019 6:34 pm
Thanks for the reply, however I have no idea where to start, I have loaded nextstart and tinkered around. Perhaps you could point me in the right direction? Or maybe Nexter will be along.
I have searched YouTube and come up with a video published in 2008 it shows what was called then the superbar a lot of water has flowed under the bridge since then.
Technobable
Users browsing this forum: Amazon [Bot], Apple [Bot], Majestic-12 [Bot] and 82 guests
