 Post subject: Nexstart issue
PostPosted: Fri Aug 16, 2019 6:24 pm
I am having an issue with nexstart, it is always on top even if I uncheck it in the advanced settings, it the cursor goes to the bottom of the screen if my mouse moves it takes the focus off the window I am currently working on and interrupts typing or other tasks, any ideas what I am doing wrong?
 Post subject: Re: Nexstart issue
PostPosted: Sat Aug 17, 2019 4:28 am
Sounds to me like you set up a hotspot to activate it with an edge bump on the bottom edge of your screen. Go look through your hotspot settings for an enabled hotspot that is activated by bumping the bottom edge of your screen.
PostPosted: Sat Aug 17, 2019 5:43 am
ok will do thank you
PostPosted: Sun Aug 18, 2019 8:21 pm
Also check the settings in NextSTART Preferences -> Taskbar tab -> Taskbar Settings -> Advanced
Users browsing this forum: Apple [Bot], Google [Bot] and 69 guests
