 Post subject: Dock Icon Behavior
PostPosted: Fri Jul 19, 2019 11:29 pm
Hy,
default is: 1 Click opens up the Menu -double click open/collaps the Dock...
Can I change this behavior?
 Post subject: Re: Dock Icon Behavior
PostPosted: Sat Jul 20, 2019 11:05 am
No, the behavior cannot be changed. The behavior of the control icon is essential to uncollapse **floating** docks, for instance.
PostPosted: Sun Jul 21, 2019 12:07 am
YES! I Know!
But to Change 1-Click and 2-Click behavior..?
PostPosted: Tue Jul 23, 2019 12:27 am
You can't for a variety of reasons, which is what I tried to explain to you above.
PostPosted: Tue Jul 23, 2019 8:32 pm
Maybe my englis is to bad....? :-)
OK..
BUT.. Maybe something for the Wishlist:
A Element just to shrink / expand the bar, WITHOUT a link tp the prefs?
Or i have overseen somthing like that..?
Users browsing this forum: Amazon [Bot] and 81 guests
