 Post subject: I can't drag a shelf anywhere
PostPosted: Fri Jun 14, 2019 11:23 pm
I have created a shelf. I would prefer it be aligned top center but when I dock it there it stays on top of anything else I open.
If I don't dock it anywhere I cannot move around at all but it stays behind open programs.
How can I either dock it to the top and have it go behind open programs OR at least be able to drag it up to the top?
 Post subject: Re: I can't drag a shelf anywhere
PostPosted: Sun Jun 16, 2019 12:05 pm
Open the Shelf Properties dialog, go to the Position tab and *uncheck* 'Keep tabs above other windows when the shelf is collapsed'.
This will prevent the Shelf tabs from always staying on top of other windows when the Shelf is closed/collapsed.
You might also want to try toggling the 'Prevent maximized windows from overlapping the shelf' setting in that same Position tab - also check what it says under 'Always keep above other windows?'.
Users browsing this forum: Amazon [Bot], Apple [Bot], Majestic-12 [Bot] and 86 guests
