 Post subject: Launch new Chrome instance from dock.
PostPosted: Thu Apr 18, 2019 8:13 pm
Apologies in advance if this has been answered before. My search didn't come up with results.
I have two Chrome instances that are always open in my second monitor. I would like to launch a new Chrome instance when I single click on the Chrome icon in my dock. I know that I can double click, but I'm not too fond of that.
I have unchecked the "Do not launch multiple sessions on the same application" setting and have also played around with the Tasklist Actions, but I have not been able to have it work as described above.
Any ideas would be highly appreciated.
Thank you.
 Post subject: Re: Launch new Chrome instance from dock.
PostPosted: Fri Apr 19, 2019 1:50 am
Is the 'Combine dock icons with running applications' enabled? If not, you must click on the Chrome icon on the *left* side of the dock to launch a new session (assuming 'Do not launch multiple sessions...' is also disabled, as you say).
Otherwise, what exactly are your settings for the dock in terms of running applications so I can try to reproduce the issue here?
PostPosted: Fri Apr 19, 2019 1:57 am
Hello Jorge.
Thanks for the fast reply.
'Combine dock icons with running applications' is indeed enabled.
My Running Applications settings are these: https://i.imgur.com/9nT2HsA.png
PostPosted: Thu May 23, 2019 10:17 am
I hate bumping posts, but...any luck?
PostPosted: Thu May 23, 2019 5:22 pm
Don't hate it, I had completely forgotten about this thread, sorry. :(
Let's try something: place a shortcut to Notepad on the dock. Now click on it to open Notepad. With Notepad open, click on the shortcut in the dock again. What happens? Do you get a second Notepad session?
PostPosted: Thu May 23, 2019 6:07 pm
No problem Jorge!
I did what you asked. Just like Chrome, first Notepad launches, second one doesn't.
If I double click, a second Notepad launches.
PostPosted: Thu May 23, 2019 6:26 pm
Ok, gotcha thanks, managed to reproduce it here with your settings.
I'll get back to you soon.
PostPosted: Thu May 23, 2019 6:33 pm
Ok, fixed it for next release.
PostPosted: Thu May 23, 2019 6:41 pm
Much appreciated!!
PostPosted: Sat Aug 24, 2019 1:10 am
This particular fix isn't released yet, correct?
PostPosted: Sat Aug 24, 2019 2:32 am
I *think* it's already fixed in the latest public beta (if you enable 'Notify me of beta (test) versions' in the Advanced tab of Preferences.
PostPosted: Sat Aug 24, 2019 4:03 am
Hmm. I have a Chrome icon in my Dock and it only brings my Hangouts window (which is an instance of Chrome) to the front when I click it. This may also be relevant.
PostPosted: Sat Aug 24, 2019 7:02 am
I have that checked however I am not receiving the Beta's.
19.4 Extreme in operation.
oOSGearOo Aka Steve....
Technobable
PostPosted: Sat Aug 24, 2019 7:49 am
I also have the beta option checked but am on 19.4.
PostPosted: Sat Aug 24, 2019 9:17 am
v19.4 *is* the beta. Last official release is v19.2. :)
Users browsing this forum: Apple [Bot], Google [Bot], GPT [Bot] and 58 guests
