 Post subject: Running Indicator
PostPosted: Sun Apr 28, 2019 7:27 pm
Why do I have a running indicator for Internet Explorer on my Nexus dock when IE isn't running?
Jim Dillard
 Profile YIM
 Post subject: Re: Running Indicator
PostPosted: Mon Apr 29, 2019 5:08 am
If you right click the IE icon in the dock and select 'Dock Entry Properties', what does it say in the 'Filename' field?
PostPosted: Mon Apr 29, 2019 5:16 pm
C:\Program Files\Internet Explorer\iexplore.exe
A reboot took care of it. Odd though.
Jim Dillard
 Profile YIM
PostPosted: Mon Apr 29, 2019 6:25 pm
You should have opened the Windows Task Manager in the details tab and looked for iexplore.exe - pretty sure you would have found it was indeed running.
PostPosted: Mon Apr 29, 2019 11:10 pm
Did that, wasn't there. Having same issue now, gonna check task manager again.
OK, it was there. Odd that it would run after I close it.
Jim Dillard
 Profile YIM
PostPosted: Tue Apr 30, 2019 3:51 pm
Told ya. :P :wink:
PostPosted: Tue Apr 30, 2019 3:54 pm
:P
Jim Dillard
 Profile YIM
Users browsing this forum: Apple [Bot], GPT [Bot] and 44 guests
