Board index : Winstep Forums : General Discussion  [ 1023 posts ] Go to page Previous  1, 2, 3, 4, 5 ... 69  Next
PostPosted: Mon Jan 30, 2006 8:58 pm
A nextstep style file manager would be great.
Olivier
PostPosted: Mon Jan 30, 2006 10:32 pm
Hmmmm.... How many more people would also (still?) like to see this?
PostPosted: Fri Mar 03, 2006 2:22 am
Referring to the Next Style file browser...absolutely. It should be just like the one that came with Nexus :P Don't forget the side-scrolling / retractable shelf / somehow expandable shelf.
James Senick
PostPosted: Fri Mar 03, 2006 7:59 pm
I would love to see a file browser... I used to use Winbrowser, but I think the company is defunct now, and I cannot find my install file...
-paul
 Post subject: Alarm feature
PostPosted: Thu Feb 01, 2007 12:03 pm
I would love to see a custom alarm feature added to the winstep clock. Is this possible?
PostPosted: Thu Feb 01, 2007 12:18 pm
Yes. Been on the works for AGES but never actually implemented.
PostPosted: Wed Jun 20, 2007 5:58 am
Sure, skin explorer to match the desktop, and maybe add some sound themes like thethemedoctor did for win98.
PostPosted: Fri Sep 07, 2007 10:58 pm
Virtual window manager that can integrate into WS, NS or Nexus. Or a way to say integrate a VM like altdesk.
A way to drag and drop from an NS menu to a Nexus dock or WS shelf.
When a Nexus dock is created from a WS shelf, offer an integration options so changes to one are replicated to the other
 Profile ICQ
PostPosted: Mon Sep 10, 2007 5:48 pm
Just press SHIFT (move) or CTRL (copy) when dragging from a NextSTART menu.
PostPosted: Wed Sep 12, 2007 1:12 am
Now that is a fast feature implementation 8) Thanks!
 Profile ICQ
PostPosted: Wed Sep 12, 2007 1:33 am
Yep, implemented even before you asked for it. :wink:
PostPosted: Mon Nov 12, 2007 4:03 am
Uptime monitor? I know others have mentioned it's built in, but I can't find it in any of the internal commands. Has it been removed? Or is it another name?
BTW, I've written a little standalone uptime manager that I've been using since win98 days. It's tiny, sits in the taskbar, and keeps not only a running total, but also graphical display of the entire time the system has been running (while my little app is running, of course!).
it normally runs in the system tray, but there are options to leave it on the desktop (no transparency code included, I built it with Delphi 3.0) But I'd be more than happy to port it or offer it to see if it's useful/practical... No strings attached!
Only problem is, it currently uses the registry (only HKLM, so permissions shouldn't be a problem). I've attached a little screenshot of what the reporting tool currently looks like...
The way it works is, each reboot it autoruns and prompts you for a tag or description. Then it stores that, and every 10 minutes (configurable) it checks to see if the current uptime is consistent, and updates the counter if so, or assumes the system has been rebooted and finalises the last count and initiates a new one.
It's real simple and a bit clunky (no browse for where to save the report image, etc), but it's absolutely rock solid and idiot-proof. Well, this idiot anyway.
PostPosted: Mon Nov 12, 2007 5:30 pm
Hmmm, that's because it's actually a 'System Uptime' item type on a NextSTART menu.
Nice uptime manager you've got there, btw. :D
PostPosted: Tue Nov 13, 2007 12:09 am
Ah, thank you for that info!
That's actually a really cool tool, and it's built in! Excellent. You definitely don't need my top-heavy tracker code at all.
PostPosted: Tue Nov 27, 2007 10:14 pm
  • Nexus needs to be faster. Animations are very slow and eat too many CPU cycles. For speed comparisons check out Rocket Dock. Nexus flat out chugs on my 1.7ghz Pentium M (Santa Rosa) laptop with 2 gb of RAM and a 128mb ATI X700 Video card. Running XP Pro SP2
 Profile ICQ
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 1023 posts ] Go to page Previous  1, 2, 3, 4, 5 ... 69  Next
Users browsing this forum: Amazon [Bot], Google [Bot] and 57 guests
