 Post subject: Toolbar Disappearing
PostPosted: Sat Feb 23, 2019 5:41 pm
The toolbar was on the wrong monitor. Instead of right-clicking to open preferences and move it, I double-clicked. I have killed it from Task Manager and re-opened, but it won't come back. And I don't see any way to get into the preferences.
Any thoughts?
 Post subject: Re: Toolbar Disappearing
PostPosted: Sat Feb 23, 2019 5:45 pm
You murderer!!!!! How could you?! Such a cute innocent little toolbar... :P
By 'toolbar' I am going to assume you mean the dock. So, double clicking the Nexus control icon just makes the dock 'hide away' into the screen edge. Getting it back should be a simple matter of bumping that same screen edge with the mouse pointer (assuming you didn't go crazy changing settings).
Either way, provided Nexus is running you should be able to get into Preferences either by pressing CTRL+F11 or clicking the icon in the system tray (notification area).
PostPosted: Sat Feb 23, 2019 6:32 pm
Jorge, thanks for the incredibly quick reply, and for the laugh!
The Ctrl-F11 shortcut is priceless. I often jump from 3 monitors to one or two in a conference room, and need to make changes to the location of the dock, or close it. I'm sure I'll use that daily.
Cheers,
Peter
Users browsing this forum: Amazon [Bot], GPT [Bot] and 64 guests
