 Post subject: Inserting new item
PostPosted: Tue Feb 19, 2019 8:03 pm
When I insert a new item (dock, shelf, start menu) and I pick the item type (program, folder, file, or any location on my PC), then I have to type in the path to it in the field on the properties window. It would be helpful to have a browse button to browse to the file/folder path.
 Post subject: Re: Inserting new item
PostPosted: Tue Feb 19, 2019 8:37 pm
There is - when you have the 'New Item Properties' window open, there's a 'Find Item' button near the bottom of the window.
Easier still, in most cases - just use drag-and-drop. :)
Users browsing this forum: Amazon [Bot], Apple [Bot], Google [Bot], GPT [Bot] and 48 guests
