 Post subject: have 2 dock and more
PostPosted: Sat Feb 16, 2019 1:46 pm
Hello,
sorry for my english ... I'm french.
i am currently testing the dock and i would like to know, is it possible to install 2 dock or 3?
Thank you and good day !!
 Post subject: Re: have 2 dock and more
PostPosted: Sat Feb 16, 2019 2:14 pm
not with the free version, but with the paid version you can have as many docks as you want
PostPosted: Sat Feb 16, 2019 6:14 pm
I don't know which product you're using, but I recommend using Xtreme. It's the highest level of all the versions. You can test it out first using the trial version.
https://www.winstep.net/xtreme.asp
PostPosted: Sun Feb 17, 2019 6:06 am
Merci !! j ai bien l intention d acheter la top , parce que je l aime bien !! :P
Users browsing this forum: Apple [Bot], GPT [Bot], winstep and 46 guests
