 Post subject: bug? blue bar covers chrome tabs
PostPosted: Thu Jan 31, 2019 11:28 am
A blue bar covering chrome tabs shows up at random on my computer when winstep is running. The problem goes away when I stop the program.
OS is windows 10, with the following software versions:
workshelf 18.12.1475
WSUpdate 18.11.0195
Winstep 18.11.0117
WsxService 18.06.0096
WsxMMTimer 1.00.0008
Please see the attached screenshot
Any idea how to fix this?
 Post subject: Re: bug? blue bar covers chrome tabs
PostPosted: Thu Jan 31, 2019 5:01 pm
Hmmm... try adding Chrome to the Thumbnail Exclusion List:
1. Open WorkShelf Preferences
2. Go to the Tasks tab.
3. Click the Advanced button.
4. Click Thumbnail Exclusion List button.
5. Click Add.
6. If Chrome is running, select it from the panel on the left, otherwise type in "chrome.exe" (without the quotes).
7. Press OK on all the dialogs.
PostPosted: Thu Jan 31, 2019 5:19 pm
Couple of observations though:
1. I also run Windows 10 and I don't have that problem with Chrome.
2. That blue bar is a Windows 7 titlebar, not a Windows 10 titlebar.
PostPosted: Thu Jan 31, 2019 11:43 pm
5. Click Add.
Thanks!! that solved the problem.
PostPosted: Thu Jan 31, 2019 11:45 pm
weird, I am running windows 10.
PostPosted: Fri Feb 01, 2019 12:57 am
Not necessarily so weird. While I can't speak for Chrome - as wouldn't touch it with a barge pole, too insecure and don't trust the big 'G' ;) - some apps will continue to display a Win 7 title bar etc. under Win 10. Have several here that do.
Users browsing this forum: Amazon [Bot], Apple [Bot], Bing [Bot], DuckDuckGo [Bot], Google Adsense [Bot], GPT [Bot], Picco14 and 37 guests
