 Post subject: Toggle notifications (= Do not disturbe) with Nexus
PostPosted: Tue Jan 15, 2019 10:33 am
Hi Jorge,
I looked through all options given in Nexus (Ultimate), but it seems there is no vanilla way for this - would it be possible to have a on/off toggle for enabling notifications? While at work, I have times when I don't want to be notified, especially by my e-mail app and Chrome. Would there be a simple way of toggling the system settings for notifications? The 'Action center' thing would possibly get close, but probably doesn't show up anything here because I am on an Insider Preview, yet still it would need a few extra clicks anyway :).
Thanks as usual in advance ;) .
 Post subject: Re: Toggle notifications (= Do not disturbe) with Nexus
PostPosted: Fri Jan 18, 2019 11:54 am
There is no Internal Command for this, but you can get the same thing by opening Preferences, going to the Sounds tab and enabling the 'Disable all voices' option.
PostPosted: Fri Jan 18, 2019 12:12 pm
Hi Jorge, no, that is something different - it disables system sounds, but not notifications on your screen :). The action center dock element is yet the closest to get there it seems.
Users browsing this forum: Apple [Bot], Google [Bot], GPT [Bot] and 35 guests
