Board index : Winstep Forums : General Discussion  [ 675 posts ] Go to page Previous  1 ... 41, 42, 43, 44, 45
PostPosted: Fri Dec 14, 2018 12:10 am
You may have overlooked my two brief queries below Jorge, so just in case posting again. No pressure, but one would like to know. :)
Chuck wrote:
Reserved space is now... wait for it... reserving space! Seems to work from startup, disconnect/reconnect of external monitor, and system going to sleep.
Great work Jorge!
Yay!!! We really need that dance emoticon ahaha :mrgreen:
Thanks for the feedback, Chuck! :)
So all clear now and done and dusted? :)
What about my license query from a couple of replies ago in re: VMs?
And, as we seem to be entering calmer waters all round now, any chance of having a quick look at my theme re: the vertical/horizontal menu titlebar problem Jorge? Shouldn't take you more than a few short minutes to figure it out, :) Then I could at last get back to doing some work on themes and finish that particular one by doing the taskbar etc.
 Post subject: Re: Windows Focus bug
PostPosted: Fri Dec 14, 2018 11:16 am
Jorge wrote:
If the free version of Nexus, open Preferences and go to the Behavior tab. If any of the other, open the Dock Properties dialog for that dock and go to the Behavior tab.
Now click the Activation Settings button. In the Activation Settings dialog, is 'Bring dock forward on mouse over' enabled? If so, what is the pop up delay? Does disabling this setting solve the problem?
Hi Jorge,
This windows focus problem has bothered me for years. I was patient, thinking it would be fixed one day. I thought I had tried every setting there is.
Your post gave me the clue I needed. My 'Bring dock forward on mouse over' was greyed out and not selectable. I realized that my configuration settings are corrupt and have been for years. {shudder}
I started over from scratch, set everything up again, and the windows focus problem just went away.
Thank-you for creating this software.
PostPosted: Mon Dec 17, 2018 8:19 am
v18.12 has just been officially released. :D
PostPosted: Mon Dec 17, 2018 1:35 pm
Awesome.
Installed. The missing text bug has been fixed.
PostPosted: Mon Dec 17, 2018 8:42 pm
Everything's just dandy here. :)
Still waiting to hear re: my previous here.
PostPosted: Mon Dec 17, 2018 8:47 pm
I know... let things settle down a bit more please. :)
PostPosted: Mon Dec 17, 2018 11:29 pm
Just a little info that may be of interest to you - WorkShelf is rock solid meanwhile. I don't know what you've changed in the past few months, but it's been ages since the last time I've had a crash. There was a time when they were quite frequent, especially when changing monitors.
I've even created a task for this with Robotask. As soon as the WorkShelf process is not running anymore, it gets automatically restarted.
Until now I had to disable this task on any Winstep update, since it would restart it in the midst of the update.
I've just realized that this task is not necessary anymore and finally deleted it. :)
PostPosted: Tue Dec 18, 2018 12:52 am
And you finally did it! Next Start doesn't run anymore after an update if it wasn't running before the update. :D This was always bugging me a little, but I didn't want to mention it since there always were more important things. ^^
PostPosted: Tue Dec 18, 2018 1:06 am
LOL. I think I even forgot to add that one to the list of changes and additions.
PostPosted: Tue Dec 18, 2018 3:06 pm
OK, you got it. :)
But I'll come out shooting next time. ;) (Just kidding, Jorge, just kidding...)
PostPosted: Fri Dec 28, 2018 9:44 pm
I regret to inform the problem with WorkShelf and games at super resolution is still there.
Is happening again with almost every game, including Starcraft II which was working good before.
Here are the logs I collected so far.
https://drive.google.com/open?id=1Bba2u ... gOyDxpYAfW
PostPosted: Sat Dec 29, 2018 7:50 am
Wait, how can that happen. It was working and suddenly it stopped working? 'Working good before', before what?
PostPosted: Sat Dec 29, 2018 3:09 pm
I honestly don't know. It just started happening again. (windows also updated one or two times in between)
I was hoping my logs would help.
PostPosted: Mon Dec 31, 2018 12:16 am
Hmmm...maybe is not only related to Workshelf. Today Destiny 2 failed to display correctly until I closed CoreTemp.
So...might be just windows.
PostPosted: Thu Feb 07, 2019 9:07 am
Excellent topic. Thank you.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 675 posts ] Go to page Previous  1 ... 41, 42, 43, 44, 45
Users browsing this forum: Amazon [Bot], Apple [Bot], Google [Bot], GPT [Bot] and 48 guests
