 Post subject: taskbar
PostPosted: Sat Dec 15, 2018 12:13 am
I would like the taskbar to not fade
hi I'm trying for a few days but I could not
I would like to know if I can change that instead of lowering the bar opens and closes the desktop
File comment: cattura
 Post subject: Re: taskbar
PostPosted: Sat Dec 15, 2018 12:16 am
Not currently, sorry.
PostPosted: Sat Dec 15, 2018 9:01 am
OK but at least there is the possibility that when you click, the task is not hidden?
2:
I saw that I can make a hotspot to open and close windows and switch to desktop mode but I can not add it to the right desktop taskbar look please my photo screen
PostPosted: Sat Dec 15, 2018 2:37 pm
Alas, you can do that for pretty much any section of the taskbar *except* that collapse handle (NextSTART Preferences -> Taskbar tab -> Taskbar Settings -> Taskbar Sections).
So just don't click on it. :)
Xtrem.73 wrote:
2:
That's not how it works. That section you are pointing to is called the systray (also known as the notification area). All icons in there are provided by Windows.
But you can add the 'Show Desktop' internal command to the Quick Launch section of the taskbar at the left. Just right click on one of the Quick Launch icons at the left of the taskbar -> Add New Quick Launch Item -> Internal Command -> Desktop -> Show Desktop.
Or drag & drop it from the dock into the Quick Launch section of the taskbar.
PostPosted: Mon Dec 17, 2018 10:24 am
hello Winstep then I tried a bit to see and as you see from the pima capture I looked for dentor settings and I found how you see from the second capture a setting disables animations done the task does not lower more but as you see from the second capture disappears the system icons notifications and do not work even the other applications on the left I have to bring the mouse down to reactivate I think you should do so as to turn off animation only on that button so that it does not fade and not impact on other functions.
otherwise I have tried many similires like windowsblind deskupx but your program and the best thanks :D
Users browsing this forum: Google [Bot] and 28 guests
