 Post subject: Why does 'Shift A' launch the dock?
PostPosted: Tue Dec 11, 2018 8:22 pm
Been through the options and cannot find one that mentions keyboard control??
 Post subject: Re: Why does 'Shift A' launch the dock?
PostPosted: Tue Dec 11, 2018 8:43 pm
Because you set it to activate the dock but now you no longer remember how you did it? :wink:
And by the way, you mean *activate* and not *launch*, right? Very different things. :)
Anyway, the settings are exactly where they should be: Dock Properties -> Behavior tab -> Activation Settings -> Hot key.
If you have the dock control icon visible in the dock (the icon that says Nexus) you can also right click the icon, select Dock Entry Properties from the context menu that pops up and change the hotkey from there as well.
PostPosted: Tue Dec 11, 2018 8:58 pm
Yes you're right I missed that. Many thanks much appreciated.
Launch vs activate. It looks very like a launch to me.
PostPosted: Tue Dec 11, 2018 9:01 pm
Eheh. Launch is normally used for when you are 'launching' an application (which is previously not running). The dock is already running when hidden, so you're basically just 'activating' (showing) it.
Just pointed this out because it's very easy to get everyone confused when using different terminologies. :)
Users browsing this forum: GPT [Bot] and 41 guests
