 Post subject: Problem opening a new program or window
PostPosted: Thu Nov 22, 2018 11:19 am
I seem to be having an issue, Say your browsing the web on Firefox and you open a folder, When you move you mouse to the folder window it automatically jumps right back to Firefox, Seems to do this no matter what I am doing and whenever I open a new window or program, Once you mouse over the new window/program you just opened it jumps righ back to the previous open window, Anyone have any thoughts on this ?
By the way I am running Windows 7 64 bit and I am only using the Workshelf
 Post subject: Re: Problem opening a new program or window
PostPosted: Thu Nov 22, 2018 11:42 am
Well, I never saw anything like that here, and I'm also running Windows 7 64 bit.
What version of WorkShelf are you running (top right corner of the About tab in Preferences)?
Are you sure this is an issue related to WorkShelf (i.e.; does it stop happening if you exit the application)?
Are you sure it's WorkShelf you mean and not the free version of Nexus (couldn't find the email address you're using on the forums on our registrations database) ?
Finally, it doesn't seem it was always like this, or you would have complained sooner when you mentioned that temperature discrepancy regarding the weather module. So, when did it start happening?
PostPosted: Thu Nov 22, 2018 3:32 pm
It says Winstep Extreme Version 18.10 in add remove programs, I am not sure what email was used I will have to ask, It is a laptop that was a gift to me that was already setup when I got it.
Yes its is gone once I exit workshelf.
No it has been like this since I got the laptop I just haven't had the time to post about it had surgery just after temperature post.
PostPosted: Thu Nov 22, 2018 4:03 pm
Strange. Nobody is complaining about such an issue either.
Perhaps the new v18.11 beta will solve your problem, but before you try to install it I need to know if your license key will work with the beta.
At the bottom of the About tab in WorkShelf Preferences it will say 'This software is registered to...' and right below it should say 'License key is valid for all upgrades released until...'
What is the date?
PostPosted: Thu Nov 22, 2018 5:21 pm
I put Xtreme on my Windows 7 X64 system a few weeks ago, but only the regular 18.10. Haven't seen any of this sort of thing there. But have to add that haven't been using that system extensively lately.
PostPosted: Thu Nov 22, 2018 5:28 pm
been running xtreme on win 7 x64 all the while, havent encountered the issue
Users browsing this forum: Apple [Bot], Google [Bot] and 39 guests
