Board index : Winstep Forums : General Discussion  [ 675 posts ] Go to page Previous  1 ... 26, 27, 28, 29, 30, 31, 32 ... 45  Next
PostPosted: Sat Nov 10, 2018 7:35 pm
Jesus Christ! It's like if you guys were running a completely different version there - I don't seen ANY of those issues here.
Sacco, can you reproduce oOSGearOo issue with the Search bar there?
Also, a dock is NOT supposed to auto hide while a grid stack is open. It never does here, but does so immediately there. Why?!
PostPosted: Sat Nov 10, 2018 7:43 pm
The Control Panel tab type of Shelfs does not works with the search filter. It freezes the workshelf when you start typing.
PostPosted: Sat Nov 10, 2018 7:49 pm
Would you like to have my settings and my database?
PostPosted: Sat Nov 10, 2018 7:50 pm
oOSGearOo wrote:
Also not from the video the text displaying in the bottom left, of the video.
Ok, fixed those. The Shelf is not supposed to accept key presses or pop up the Search Filter while collapsed, but was.
PostPosted: Sat Nov 10, 2018 7:51 pm
What do you mean by 'database'? A backup of your settings might be useful indeed, thanks. :)
PostPosted: Sat Nov 10, 2018 7:59 pm
i think 'disable quick search' is one of the settings that could be global?
PostPosted: Sat Nov 10, 2018 8:08 pm
It *IS* global. Don't you see the little global icon next to it?
*All* the settings the in Advanced Behavior dialog of Shelves/Drawers/Grid Stacks are now global.
PostPosted: Sat Nov 10, 2018 8:20 pm
Here are my settings.
As database I mean a folder that has all the shortcuts and some other files. (300mb in size so is doable)
PostPosted: Sat Nov 10, 2018 8:22 pm
LOL. Ah, no, thanks. :)
PostPosted: Sat Nov 10, 2018 9:25 pm
If I set the workshelf "always on top" each sub grid stack will open behind it. Once set to normal they open at the top of the z order.
Should have fixed this.
PostPosted: Sat Nov 10, 2018 9:33 pm
I guess that is why oOSGearOo is getting all those errors (he's using the Search Box on a Control Panel tab type) although I am still unable to reproduce here.
Going to try on a Windows 10 VM.
EDIT: Froze on Windows 10. Time to start digging.
EDIT 2: A quick explanation that might be interesting:
The Control Panel tab is 'special' on 64 bit systems, as its contents cannot be properly enumerated from a 32 bit application.
This is a bit stupid as the shell should offer some degree of isolation, but it seems to be because control panel (.CPL) items are actually Windows DLLs, and 64 bit DLLs cannot run inside a 32 bit process space.
So, if you try to enumerate Control Panel items on a 64 bit system from inside a 32 bit application using the standard method, all you get are the 32 bit Control Panel items. None of the 64 bit Control Panel items (i.e.; most of them) will show up.
So, the Shelf must use a non-standard way to get those items, and it seems like it's this that is causing problems.
PostPosted: Sat Nov 10, 2018 9:58 pm
Ok, figured it out: I was missing a ByVal keyword when deleting a shell namespace item
Ooops.
PostPosted: Sun Nov 11, 2018 12:47 am
I find that I need to enter in the same'ish text move the mouse over so the icon gets focus, then to continue to type I think. HIH
oOSGearOo Aka Steve....
Technobable
PostPosted: Sun Nov 11, 2018 3:38 am
oOSGearOo wrote:
Firstly being through the power option Icons in control panel in a shelf are not displaying properly we have still the “?”Icon.
Fixed your question mark (?) Power Options icon, you nitpicker! :wink:
You didn't say anything about your previous pet peeve, the Network tab.
PostPosted: Sun Nov 11, 2018 4:53 am
This one shows stacks over stacks and stacks refusing to close unless I click again in the gridstack main icon.
They seem to be acting as if they thought they were detached.
If you restart the software, do they immediately begin acting like that or only after a while?
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 675 posts ] Go to page Previous  1 ... 26, 27, 28, 29, 30, 31, 32 ... 45  Next
Users browsing this forum: Google [Bot] and 14 guests
