 Post subject: updated to latest v. Ultimate - text problem
PostPosted: Tue Oct 30, 2018 6:24 pm
Dock[s]: since the update at hover over an item [icon] the description text now is horrifically ugly: bright yellow [bold] on a black background. Not only ugly but hard to read. I have winstep since many years and am familiar with every modification/customization possible - but this one has me at a loss.
Even importing a saved file did not change this one.
I changed the font to just white, no bold, no yellow no black background -
I very much hat this now.
Plus I have a second dock [both my docks are stationary [one on top and one on the left of my screen]this one also ignores my choice of "not to bounce when opening].
I don't understand why this is so complicated now.
Appreciate a resolve.
I would not have updated if I this is a common problem now. I was just fine with my old version.
Hope to have an answer soon for this.
 Post subject: Re: updated to latest v. Ultimate - text problem
PostPosted: Tue Oct 30, 2018 7:07 pm
What version were you running previously? Nexus Ultimate or Winstep Xtreme?
Also, can you please post a screenshot showing the bright yellow label text on a black background (press the PRTSCR key to capture a screenshot of your desktop to your clipboard if you find it difficult, then open a paint program, paste the image in the clipboard to it and save it as JPG)?
Anyway, from what I understood by reading your older posts, the version you were running previously was VERY OLD, i.e.; dating back to 2012?
There have been literally hundreds of changes and additions made to Winstep applications since then - this is what you get for not keeping up-to-date: feature shock. :wink:
PostPosted: Tue Oct 30, 2018 8:44 pm
I always used Ultimate.
The countless updates - I get.
But it actually asked me to "fresh install. That is what I then wound up doing and using the new key.
And 2012 is not correct it was actually 2014. Does not make much difference - fact is it was way outdated. I was on hiatus due to several heart attacks, and had zero use for a computer during this entire time.
I am back now, and paid. Upgraded.
It still should be able to respect the font at least. Nowhere do I ever have "bold" enabled, not in the theme or the custom areas, preferences etc.
All I need is just a proper suggestion what to do.
PostPosted: Tue Oct 30, 2018 9:22 pm
Sorry to hear about that, must have been a really scary time. :( Glad you're doing better now, though. :)
You mention it as if that was a bad thing? :D
And I need the screenshot I asked you about above to make sure we are on the same page. :)
PostPosted: Thu Nov 01, 2018 10:14 am
Hello?
Users browsing this forum: Apple [Bot], GPT [Bot], Majestic-12 [Bot] and 49 guests
