 Post subject: Ctrl+F
PostPosted: Sun Apr 15, 2007 10:13 am
Where can I edit the keyboard shortcuts for WorkShelf? I use Ctrl+F a lot in Firefox and that is causing WorkShelf to open when collapsed. It's probably something simple I can't find :?
There are two places: for the shelf and tabs, in the Shelf Editor dialog. For the items themselves, you will have to look at the Properties dialog for each item. :wink:
http://www.scarebear.org/
Users browsing this forum: Apple [Bot] and 81 guests
