 Post subject: Make dock appear with Windows Key?
PostPosted: Sat Sep 15, 2018 8:29 am
As the title says; is there a way to configure Nexus so that it also shows up with the windows task bar when I press the WIN/windows button on the keyboard?
 Post subject: Re: Make dock appear with Windows Key?
PostPosted: Sat Sep 15, 2018 9:12 am
No. The WIN key is system reserved.
You can assign some other keyboard shortcut to the dock though.
PostPosted: Sun Sep 16, 2018 5:12 am
hmm could you help me understand how to do that? I see a keybinding option for opening the Preferences window but nothing to make the bar appear over other apps.
PostPosted: Sun Sep 16, 2018 2:51 pm
Preferences -> Behavior tab -> Activation Settings -> Hotkey
PostPosted: Sun Sep 16, 2018 8:38 pm
Ah perfect, thank you!
PostPosted: Tue Sep 25, 2018 7:17 pm
I'll use this old post....
There's a problem when dock is set to "allocate (reserve) desktop space".
When you hide it, user expects the previously allocated space, be freeded, so other apps can use it.
PostPosted: Tue Sep 25, 2018 7:36 pm
That is not a problem, it is by design. That is how Appbars work - if you set the Windows taskbar to auto-hide it stops reserving screen space AT ALL TIMES. If you set it NOT to auto-hide, it reserves screen space AT ALL TIMES.
You cannot have an in-between for several good reasons.
If you set the dock to auto-hide then you don't need to make it reserve screen space, so just disable that option.
Also, please don't use unrelated old posts. Just make a new post.
Users browsing this forum: Apple [Bot], Google [Bot], GPT [Bot] and 39 guests
