 Post subject: Adjust pixels between dock and label?
PostPosted: Sat Aug 11, 2018 11:05 pm
Would there be a way to implement or is there an option to adjust the space between labels and icons/docks? Where as, you mouse over the icon in a dock, the label appears. Some docks are larger than others. So the text literally sits right on the edge on some themes.
Thank you in advance!
 Post subject: Re: Adjust pixels between dock and label?
PostPosted: Sat Aug 11, 2018 11:14 pm
Oh hi there, stranger! Long time no see. :P :wink:
I think this is only happening because you have the magnify effect turned off for that dock. Rather than adding yet another setting, I prefer adjusting the position of the labels for that particular case instead.
PostPosted: Sat Aug 11, 2018 11:31 pm
Hey! Yes I am alive and well. Loving NeXus as always. You are right, I do not use any mouseover effects. So when it's static, it definitely appears a bit close.
Thank you again!
PostPosted: Sun Aug 12, 2018 2:12 am
Ok, done. The position of the label when the dock is not magnifying is now based on the size of the dock's background 'border'. I tested it with several different backgrounds and it seems to work out pretty well.
In your particular case (Aero LowRes theme) the difference is 4 pixels (i.e.; the label will appear 4 pixels below where it appears now). Not a lot but more than enough for the text not to 'sit on the dock edge' as it currently does.
PostPosted: Sun Aug 12, 2018 2:57 am
Awesome! 4 px in the eyes of extreme customization is a world of difference! I will look forward to it next update!
Hope you're staying cool! Here in Seattle we FINALLY had a cool day. Didn't even break 72. :)
PostPosted: Sun Aug 12, 2018 3:32 am
MUCH cooler here now too... about 26C. :)
Users browsing this forum: Apple [Bot], Google [Bot] and 59 guests
