 Post subject: Re: Winstep extreme registration continually pops up, has ta
PostPosted: Sun Aug 05, 2018 11:44 pm
ryanfss wrote:
Installed the update - the work shelf is 18.3 but the task bar is still on lockdown and will not register so I don't know what it is for certain. I disabled AV software and windows defender(another MS fubar)and tried to register again but no luck so I really don't know what else to do.
Ok, I need you to please confirm that NextSTART has ALSO been upgraded to v18.3 (in case the file could not be overwritten). You mention that WorkShelf has, but you say nothing about NextSTART.
You should be able to access the About tab of NextSTART Preferences to confirm. Either way, please go to
right click on the nextstart.exe file, select Properties, then click on the Details tab and paste the file version here.
This is just getting weirder and weirder - as you can probably guess from the LACK of comments on this thread - and the non existence of other threads - regarding this subject, this is definitely NOT a common issue.
PostPosted: Mon Aug 06, 2018 7:16 am
File version is 18.5.0.878. And I did mention Nexstart - it will not let me choose any of the tabs, period. Registration is it and if I want to use my taskbar I have to shut down Nextstart. That is my primary problem.
PostPosted: Mon Aug 06, 2018 8:51 am
Well, that explains it, doesn't it?
What version did you just install? v18.3.
What is the version of NextSTART running on your system? v18.5.
Your license key was good for all updates released until April 23 2018. This means it will still work with v18.3 (released in March 31 2018) but NOT with v18.5 (released in June 1 2018).
How you got into a situation where the version of WorkShelf running in your system was v18.1 but the version of NextSTART was v18.5 is anybody's guess - you will probably know it better than I do because you didn't mention downloading the v18.5 update. The practical result of that is that WorkShelf worked but NextSTART didn't.
Now, when you perform an upgrade, the install will NOT overwrite newer version files. This explains why installing v18.3 still left NextSTART v18.5 running in your system instead of replacing it with the older v18.3.
So, here is what you need to do:
1. Exit all running Winstep applications.
2. Go to
and delete the NextSTART.exe executable.
3. Re-install v18.3 *ON TOP* again (i.e.; do NOT uninstall anything first).
4. NextSTART should run properly now. Double check the version number to make sure it is now v18.3.
PostPosted: Tue Aug 07, 2018 4:15 am
Is there anything else that can be done or I'm just outta luck?
PostPosted: Tue Aug 07, 2018 4:18 am
Eh? I left instructions on what you should do above (blind bat!). :)
Here it is again:
2. Go to
PostPosted: Tue Aug 07, 2018 4:24 am
Damn, you're right. Only half a page don't know how I missed it. OK, I'll post results. Thanks
PostPosted: Tue Aug 07, 2018 4:34 am
Works perfectly, thank you for your time and diligence.
PostPosted: Tue Aug 07, 2018 4:52 am
My pleasure! Glad we could get to the bottom of this and sort it out. :)
Users browsing this forum: Amazon [Bot], GPT [Bot] and 34 guests
