 Post subject: Shelf position error when taskbar is vertical
PostPosted: Tue Jul 03, 2018 8:27 pm
Hi, when taskbar is vertical, the shelf overlaps with it.
This is because programers set "Left=0" instead of "left=spiDektopArea"
Greetings!
 Post subject: Re: Shelf position error when taskbar is vertical
PostPosted: Tue Jul 03, 2018 8:39 pm
Do you have the Shelf set to 'Respect space reserved by other docks, toolbars and screen objects' (Shelf Properties -> Position tab)?
PostPosted: Wed Jul 04, 2018 9:53 pm
Yes, i have it
PostPosted: Thu Jul 05, 2018 5:53 am
Well, you were right, and I fixed it for the next release.
HOWEVER, I have a nagging feeling Windows at some point changed the way appbars were working and that is what caused the problem.
ABM_QUERYPOS should return an adjusted rectangle for an appbar, and that should include adjusted coordinates for ALL edges, not just the requested docking edge. Ah well.
PostPosted: Thu Aug 02, 2018 6:05 pm
Can you download the beta of v18.8 (if you haven't already) to confirm if it indeed fixed the appbar issue and then let me know here, please? :)
PostPosted: Thu Aug 02, 2018 8:55 pm
Sure my friend... as Soon as U grant me access to beta :)
PostPosted: Thu Aug 02, 2018 10:55 pm
LOL. :)
It's a public beta. Just enable 'Notify me of beta (test) versions' in the Advanced tab of Preferences then check for updates.
PostPosted: Fri Aug 03, 2018 4:11 am
Ok, about 18.8 release, now it respect ok the space reserved, and do not overlap.
But for some strange reason, it generates a space (or margin) on left/top/right of desktop (see image)
(PD: Date format now is ok! but that is another post)
PostPosted: Fri Aug 03, 2018 5:51 pm
Ahah. That's theme related - it's because of the alpha shadows at the edges of the Shelf background bitmap. Try a different theme or a white desktop background and you will see what I mean.
The space at the top is for the same reason and also because you have the Shelf docked to the top but inverted (i.e.; tabs on top).
PostPosted: Mon Sep 24, 2018 11:52 am
You were right Jorge!
Can you point me in the right direction to contribute with my own themes?
PostPosted: Mon Sep 24, 2018 12:39 pm
You should wait until I do some further work on the Winstep Theme Builder...
Dealing with text configuration files and figuring out what the parameters mean is not easy nor for everyone.
PostPosted: Mon Sep 24, 2018 6:36 pm
And we're all waiting with bated breath Jorge. :)
PostPosted: Tue Sep 25, 2018 6:41 am
I'm not sure some of us can wait that long.
PostPosted: Tue Sep 25, 2018 9:00 am
Neither do I - some of us may well pop our clogs before then! At any rate, it's been announced as on the current upgrade plan weeks ago and we're still waiting to even hear.... :P
:Singing: 'Why are we waiting, why-y-y are we waiting, oh why, oh why......' :Repeat: ;)
PostPosted: Tue Sep 25, 2018 10:33 am
"It will be ready when it's ready."
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 42 guests
