Board index : Winstep Forums : General Discussion  [ 149 posts ] Go to page Previous  1, 2, 3, 4, 5 ... 10  Next
PostPosted: Sun Jan 28, 2018 6:58 pm
Ok, slight existential doubt:
The icon for the new 'Power Saving' internal command is a green leaf, which is a symbol of energy saving.
And here lies the problem: on one side, a green button should mean maximum energy savings are in effect, on the other, green should be the normal state, yellow the intermediate, and red should mean full power savings are in effect (since this will disable parts of the normal functioning of the application).
_OR_ (a bit like the Alarm Manager IC) gray scale for off, green for on (Medium) and red for Full power savings. Or should green be Full power savings and yellow Medium?
What do you guys think?
Also, there is an alternative icon where the green-yellow-red state progression might make more sense, but I like the green leaf icon better:
PostPosted: Sun Jan 28, 2018 6:59 pm
didnt means seconds, meant minutes. it was actually the clock that made me point out modules stopping working while i was watching a movie on other screen as i noticed wrong time
Yeah, but that has already been fixed in v18.1.
PostPosted: Sun Jan 28, 2018 7:45 pm
i know, my point is that the clock is one of the things that shouldnt go below once a minute (opposed to some things that can stop completely)
PostPosted: Sun Jan 28, 2018 8:19 pm
Goes without saying... and how about an opinion on the above? :P
PostPosted: Sun Jan 28, 2018 9:37 pm
maybe grey for off, green+ white for medium, green+orange for max?
PostPosted: Sun Jan 28, 2018 9:48 pm
Well, only the button itself changes color, the leaf remains white.
So gray button for off, green button for medium, orange button for max? Why orange and not red?
PostPosted: Sun Jan 28, 2018 10:49 pm
In the mean time here is what I have so far:
Medium Power Saving Mode:
1. All cosmetic animations are disabled. This means:
a) Wanda stops swimming.
b) Rotating globe style of the Email Checker module stops rotating even if there is mail.
c) Smooth gauge needle animations are disabled (i.e.; needle jumps from value to value)
d) User Interface slide animations are disabled.
e) Battery module charging animation is disabled.
f) Flip calendar day switching animation is disabled.
g) Moon module image is only refreshed once per hour instead of every 3 minutes.
2. All modules that usually update once per second start updating every 2 seconds.
3. Clock module is only updated every minute instead of every second.
Full Power Saving Mode:
1. In addition to everything already happening for Medium Power Saving mode, modules now only update once every 4 seconds.
This is just what I managed to come up with so far. There is a lot more that can be done throughout the application, but the module update rate - and disabling cosmetic animations - is, without a doubt, what will have the most impact. Pity there is no easy way to measure it.
Besides decreasing the modules update rate, I wonder what else should be reserved to the highest power saving mode. The idea is that the Medium Power Saving Mode is something the user would want to *voluntarily* activate the second his laptop starts running on battery, so it should have a noticeable effect but not be so restrictive that the user would not want to activate it unless his battery was almost critical.
For instance, what about the Shelf expanding/collapsing, sub-dock opening, etc, animations: in which mode should those be disabled?
Any ideas? This is always easier with feedback from you guys. :)
PostPosted: Sun Jan 28, 2018 10:51 pm
well i was thinking the whole button would change, leaf too, and i find full on complementary contrast (red on green) bit to intense, so orange instead of red
that way you would stay with logic green=eco while still having difference between modes
PostPosted: Sun Jan 28, 2018 10:58 pm
maybe adding an option for user to further be able to tweak the individual module settings for modes?
different users my have different needs,
for example some might want to keep the clock running, slow the cpu meter as default, slow down ram meter even more, and completely disable weather module, moon and netmeter but leave them showing,turn wanda off, while leaving email checker at its original settings
PostPosted: Sun Jan 28, 2018 11:01 pm
do those come up enough and use enough resources to make any difference?
if so, how big an impact do they have?
dont see them having that big of an impact that they should go into medium mode
PostPosted: Sun Jan 28, 2018 11:06 pm
what about sounds? when should all non critical sounds be turned off
(i would consider anything except new email notifications, user alarms, and piracy welcome mat non critical)
PostPosted: Sun Jan 28, 2018 11:09 pm
Absolutely everything makes a difference. It's a cumulative effect too.
No idea, it depends on usage patterns and I also have no way to measure what that impact actually is, all I know is that every little bit matters.
So, the real question must become: would disabling those animations be something that would make the user prefer NOT to activate the medium power savings mode? If so, then it should be moved to full power savings mode.
Good question. lol
But if you turn off, say, the Shelf expand/collapse animation, the associated sound effect also goes with it.
PostPosted: Sun Jan 28, 2018 11:17 pm
for one minute/hourly clock announcements cant be controlled that way (who DOES use minute clock sounds, how can that not be annoying?)
and there are probbably some more
PostPosted: Sun Jan 28, 2018 11:20 pm
could be, no idea how jarring the change would be. and no idea how many users would be bothered by it, but somehow it feels like something for full savings mode to me
PostPosted: Mon Jan 29, 2018 7:35 am
Agreed.
In the mean time added voice notifications to the events: 'Power saving enabled', 'Ultra power saving enabled' (stole the 'Ultra' from Samsung) and 'Power saving disabled'.
Don't want users getting into a power saving mode by accident and then thinking the software is broken or something. :)
Anyway, couldn't find the exact voices that powered the other voice events, had to settle for similar male and female voices. And that's just for English... how the hell do you say 'Power Saving Enabled' in German?
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 149 posts ] Go to page Previous  1, 2, 3, 4, 5 ... 10  Next
Users browsing this forum: Apple [Bot], GPT [Bot] and 41 guests
