Board index : Winstep Forums : General Discussion  [ 98 posts ] Go to page Previous  1 ... 3, 4, 5, 6, 7
PostPosted: Sun Jan 21, 2018 1:35 am
After careful deliberation I have to say I like ALL of the themes but I think I like Dark Mode (Black) the best! :D
PostPosted: Sun Jan 21, 2018 2:22 am
v18.1 is officially released. Go get it, guys! :)
This one was a true headache to release, kept running into very hard to diagnose and/or fix issues - I initially intended to sync the official release with the promotion at BDJ, but alas, that was not possible because I kept running into those last minute issues.
There are actually a TON of little fixes and enhancements that didn't make it into the change log.
Anyway, hope we don't get any more show stoppers - time to start the 'what's new after v18.1' thread - and if v18.1 has no major issues the need fixing ASAP, then I will have plenty of time to make the next release a BIGGIE in terms of added functionality.
PostPosted: Sun Jan 21, 2018 3:21 am
got this right after the update
http://prntscr.com/i3cl9t
PostPosted: Sun Jan 21, 2018 3:49 am
Grrr, thanks, glad you caught it quickly. Shouldn't be a biggie because I think it only happens on that particular dialog and most people don't set the application to ask them if they want to check for updates.
I fixed it already and silently updated the setup files for all applications.
You can download a fixed version of the Update Manager from HERE. Just unzip and run setup, no need to exit anything first.
In a few days, once the update rush has died down, I will probably issue an update to the Update Manager. This would take care of those who already downloaded the version with the glitch.
Don't want to do it now because Update Manager releases always take priority over everything else, and people would be downloading something which is already a part of the (refreshed) main application update.
PostPosted: Sun Jan 21, 2018 7:41 am
Glad to help
PostPosted: Mon Jan 22, 2018 6:50 am
I like the dark mode interface Jorge. Now it is working corectly on Windows 10 Home with latest version of WindowBlinds.
Thank you for your continuous efforts to improve the software and to fix the bugs! Good job!
PostPosted: Mon Jan 22, 2018 6:55 am
Thanks for letting me know and for the thumbs up. :)
Goes without saying: the UI is still fully compatible with WindowBlinds if you select the 'Standard User Interface' mode.
PostPosted: Mon Jan 22, 2018 7:04 am
Yes it does. Same goes for the Gray and Winstep versions. The best contrast remains with dark and Standard.
I also like the inclusion of windows accent color. Nice touch!
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 98 posts ] Go to page Previous  1 ... 3, 4, 5, 6, 7
Users browsing this forum: Google [Bot] and 25 guests
