Board index : Winstep Forums : General Discussion  [ 231 posts ] Go to page Previous  1 ... 12, 13, 14, 15, 16
 Post subject: Re: So, what's next after v17.1?
PostPosted: Sat Dec 30, 2017 10:36 pm
Probably because the problem is in one of the video codecs invoked by IExtractImage to generate the live folder thumbnails, and those are usually very system specific.
Yeah, seems to be. Just made another quick test with some non-video folders. I've dragged 10 at once to the Shelf to prevent too fast thumbnail creation, and I couldn't crash it with tab switching.
Anyway, going to open a new topic: 'What's next after v17.12?', eheh.
Alright, see you there then. :)
PostPosted: Sat Dec 30, 2017 10:40 pm
I should have a new beta fixing this and the file copy issue for you guys to play with right after New Year's. :)
PostPosted: Sat Dec 30, 2017 10:50 pm
Thank you very much for your efforts and continuous support!
PostPosted: Sun Dec 31, 2017 12:28 am
Yes, Jorge thanks a lot for your perseverance. I, toniostarcevic and everyone else is greatly appreciative of the continual advancements of your creation and the speed in which you correct bugs-even when they aren't your fault.
PostPosted: Sun Jan 14, 2018 4:06 pm
toniostarcevic wrote:
Yes, can confirm this. As soon as the parent dock icon magnifies, the sub-dock jumps to the foreground with a short delay - some tenths of a second.
Just to let you know that I just fixed this.
PostPosted: Tue Jan 16, 2018 6:06 am
regarding my previous post:
Is that only since the beta? Have you read Seeker's post above?
I did read Seeker`s post above. Actually after the 17.12 beta I did not have the crash problems, but I am quite sure it was related to Enable fast boot option, that is now deactivated. I have suspected that those crashes were related with that for a while now, but I was willing to take it as such, given the fact that the crashes happened only occasionally. That would be the reason I can not reliably test that now. I will leave that setting off for another week, then I`ll set it back to on and then see what will happen.
I have changed to fast startup for 2 weeks now and no more crashes.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 231 posts ] Go to page Previous  1 ... 12, 13, 14, 15, 16
Users browsing this forum: Google [Bot] and 26 guests
