Board index : Winstep Forums : General Discussion  [ 18 posts ] Go to page Previous  1, 2
 Post subject: Re: Dock freezing and crashing (NOT Surface Pro)
PostPosted: Tue Dec 05, 2017 2:04 pm
QTP wrote:
Steam is always updating itself in the background and often downloads shit I definitely don't need or want. Unfortunately, there is no way to stop it short of uninstalling but if I do that I can no longer play the games I purchased through them. On the other hand, millions of people use Steam so I'm thinking some other Winstep user/s might have had the same issue if it had been the cause.
Why o Why do you have steam running at startup? disable it at startup and run it manually when you want to play, unless you really, really, really want it to run automatically for convenience of automatic updates or messaging.
PostPosted: Tue Dec 05, 2017 5:41 pm
Anyway, it won't be Steam for sure, millions of people run it - problems would have been detected and fixed almost immediately.
Also, don't forget what I said is *just* a theory (although it makes perfect sense). It could be something else entirely.
PostPosted: Tue Dec 05, 2017 6:32 pm
I never thought about it but concede you are correct. Took me some time to discover where they hid the option to disable it at start-up but it's done now. Thanks for the tip! :)
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 18 posts ] Go to page Previous  1, 2
