 Post subject: Flip calendar does not show on desktop
PostPosted: Mon Dec 04, 2017 7:03 pm
All I ever see on the desktop is the day in about the correct position, but the rest of the calendar does not show. If I go to Winstep Taskbar, the day shifts to an icon on the Taskbar but I cannot get the full month calendar to show regardless of z-order, hot key, mouse action, etc. It just doesn't show.
Win 10
Latest Winstep version
0% transparency
Ultrawide monitor
Slideshow as wallpaper
 Post subject: Re: Flip calendar does not show on desktop
PostPosted: Mon Dec 04, 2017 7:14 pm
How about a screenshot of what it looks like? :wink:
PostPosted: Mon Dec 04, 2017 7:29 pm
There is nothing to show. Imagine a blank desktop with no icons or modules and the Taskbar with an icon just to the left of systray that says 4 (today) after I open the taskbar. SS attached, though.
All the other modules show, even the moon calendar.
PostPosted: Mon Dec 04, 2017 7:52 pm
Thanks for the screenshot, told me what I needed to know.
Right click on the tiny calendar module on the desktop and, from the context menu that pops up, select 'Display as Full Calendar'.
PostPosted: Mon Dec 04, 2017 7:57 pm
Actually that might not even be the problem, as otherwise the module would appear as an icon in the preview too.
When you right click on the tiny desktop calendar module, do you have a 'Detach from NextSTART' option showing up?
Also, exactly *where* is your NextSTART taskbar on the screenshot above?
PostPosted: Mon Dec 04, 2017 8:25 pm
Aha, Detach solved the problem. TB is at bottom of screen.
Tom
PostPosted: Mon Dec 04, 2017 9:03 pm
It solved the problem for you, created a problem for me: why is a module attached to the NextSTART taskbar showing up in the middle of the screen?
What are the settings for the NextSTART taskbar? Is it set to auto-hide?
Users browsing this forum: Google [Bot] and 27 guests
