 Post subject: parse error (;) at line 173
PostPosted: Mon Aug 09, 2004 3:55 pm
i recently installed nextstart software but then uninstalled it because i hadnt a clue what i was doing, anyway now when i goto switch user or log off or even wen i start my computer i have an error box that reads
i click ok several time and it appears on evey occasion and after about 10 clicks or so a windows xp security box appears sayin this computer has been locked and i have to enter my password to get in again. how do i prevent this from happenin again
PostPosted: Sat Aug 14, 2004 5:56 pm
Sorry, I have no idea what could be causing it and that has definitely nothing to do with NextSTART. Maybe the following web page will lead you on the right path to fix this problem?
http://www.duxcw.com/dcforum/DCForumID7/781.html
Good Luck.
PostPosted: Mon Mar 21, 2005 6:44 pm
I have the same problem, and it started after I deleted a startup program... :evil:
Users browsing this forum: DuckDuckGo [Bot] and 50 guests
