 Post subject: Dock separator icon
PostPosted: Sun Oct 08, 2017 5:41 pm
http://prntscr.com/guu749
i want to make a dock that has icons on the left and right ends and is empty in the middle, but i want it without separator lines/icons.
is there a way to make separator transparent/invisible? What file in the skin is used for separator?
 Post subject: Re: Dock separator icon
PostPosted: Sun Oct 08, 2017 10:59 pm
Make a completely transparent PNG image, then right click on each of those separator items in the dock, open the Dock Entry Properties dialog and type in the path to the transparent image in the Icon Path field.
PostPosted: Mon Oct 09, 2017 12:56 pm
thx
Users browsing this forum: Amazon [Bot], Apple [Bot] and 76 guests
