 Post subject: Temperature module
PostPosted: Sat Jun 17, 2017 3:01 pm
Does anyone know if a computer temperature module exists for the WS Nexus please?
 Post subject: Re: Temperature module
PostPosted: Sat Jun 17, 2017 4:05 pm
you mean CPU/GPU temperature?
AFAIK no
PostPosted: Sun Jun 18, 2017 1:00 pm
Yes. Stardock had one for ObjectDock so I thought that maybe I could get one for Nexus.
PostPosted: Mon Jun 19, 2017 8:34 pm
I'm not aware of any CPU + GPU temperature docklet for ObjectDock.
Anyway, the reason there isn't one for Winstep is because there is no standard to measure system temperatures. Each motherboard, CPU, GPU, etc, uses a different method, so it would simply be too much work to keep such a module up-to-date - after all, there are *entire* applications dedicated just to these sort of measurements (Afterburner, etc...).
PostPosted: Tue Jun 20, 2017 11:13 am
Understood. Sorry for my error.
Users browsing this forum: No registered users and 13 guests
